Eliminated Front Swaybar Squeak
Old Mar 24, 2007 | 01:46 PM
Oldvetter's Avatar
Oldvetter
Default Eliminated Front Swaybar Squeak
My car was driving me crazy, squeaking over speedbumps. Well today I had it jacked up to change manual transmission fluid, so I decided to eliminate this squeak.
Took off the front swaybar rubber bushings. Coated both swaybar and inside of bushings with diaelectric grease and replaced. Torque on bolts is 43 ft-lbs. Squeak eliminated.
Old Mar 24, 2007 | 01:58 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Mar 24, 2007 | 02:56 PM
Black 'n Tan's Avatar
Black 'n Tan
St. Jude Donor '07
Most of the folks here recommend when installing Z06 bars to place a washer underneath the bracket to shim it out slightly, then lube and install. I did it that way, so far , perfect.
John
To Eliminated Front Swaybar Squeak
