sensors not working
Mar 25, 2007 | 08:48 PM
sensors not working
my 03 sat out all winter and now the pressure reading on the dic are blank. anyone have this problem, and did it cure itself after warming the tires.
Mar 25, 2007 | 09:06 PM
Try driving around the block, they should start working. mine were a little slow too.
Mar 25, 2007 | 09:08 PM
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Quote:
Originally Posted by
krm_wi_C5
try this before you do a relearn procedure.
Mar 25, 2007 | 09:09 PM
May need to relearn if driving a short distance doesn't revive them.
Mar 25, 2007 | 09:17 PM
i drove a few miles, roads still covered in salt. how do you relearn?. battery was also dead, did that have anything to do with it?
Mar 25, 2007 | 09:27 PM
Mine started working after 500 ft or so. did you receive a message on the message center?
Mar 25, 2007 | 09:33 PM
no, just blank for front & rear
Mar 27, 2007 | 08:57 AM
Try checking them the old fashion way, then put more air if needed. Then see if they work. If there was a problem, I would think that the DIC would tell you. Also, what would be the chances of all four batteries going dead at the same time.
Mar 27, 2007 | 09:00 AM
If you need to replace them they're about $73.00 each at
www.gmpartshouse.com or less if your car is an 03.
Mar 27, 2007 | 09:12 AM
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
krm_wi_C5
Mar 27, 2007 | 09:38 AM
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
relearning is not hard to do, but you do need a magnet (like from an old speaker, or one of those nail pick up ones from a home center) to do it. If your battery went dead over the winter, this may fix it.
Mar 27, 2007 | 09:48 AM
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Also, if the battery was dead. Invest about 40 bucks for a battery tender.
