Removing Fan Shroud?
Old Mar 26, 2007 | 04:39 PM
Z0SLIK's Avatar
Z0SLIK
Default Removing Fan Shroud?
I am doing a little engine compartment upgrade in the next few weeks. I am looking for instructions on removing the front fan shroud, the large black part at the very front of the engine compartment, under the airbox or in my case under the blackwing.
Any help is greatly appreciated.
Slik
Old Mar 26, 2007 | 06:06 PM
bobdt173's Avatar
bobdt173
Cruise-In VII Veteran
Old Mar 26, 2007 | 06:24 PM
bkemp's Avatar
bkemp
Old Mar 26, 2007 | 06:25 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
I have taken mine off and if I remeber correctly you just give a little tug and it comes off the two plastic pins.You will also need to disconnect your airbridge from throttle body for some room if I'm not mistaken. Hope that helps
Old Mar 26, 2007 | 06:35 PM
oaks99's Avatar
oaks99
Old Mar 26, 2007 | 06:49 PM
dndrsn's Avatar
dndrsn
Search for a Vararam or Callaway install. It has to come out to do those mods.
Old Mar 26, 2007 | 07:59 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
before pulling the shroud, go to your local chevy dealer and get (2) of those plastic fuzzy retainers that go through the shroud on each side and into the a/c condenser, and (2) retainer rings. per callaway instructions:
remove (4) screws securing the radiator cover and then remove cover.
disconnect the hood light connector from the radiator shroud.
unplug the ambient air temperature sensor.
remove (2) metal retaining clips from plastic retainers. ( i just placed a long screwdriver between the shroud and a/c condenser and pried the plastic retainer apart. replace when installing )
raise and securely secure the car to gain access to the front shroud screws.
remove (5) screws holding the shroud to the nose.
remove (2) screws on the lower inside of the shroud. ( tip the air dam to gain access )
remove the shroud from the vehicle by pulling up and gently rocking side to side. be careful not to damage the a/c condenser fins during removal
notice: typing disclaimer
Old Mar 26, 2007 | 08:10 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Mar 26, 2007 | 08:52 PM
DavzC5's Avatar
DavzC5
From: Houston, TX www.djmotorsportaccessories.com Specializing in C5 & C6 Accessories. DJ Motorsport Accessories.
St. Jude Donor '08-'09
Cajundude has pictures of Vararam install so go here: http://www.cajundude.com/vararam.htm
Old Mar 26, 2007 | 09:42 PM
T's's Avatar
T's
St. Jude Donor '06-'07-'08
What are you doing now .......more chrome
Old Mar 26, 2007 | 09:48 PM
Good writeup by Sleasy Rider. Thanks.
Old Mar 26, 2007 | 10:04 PM
Z0SLIK's Avatar
Z0SLIK
Hey T, Nope no chrome, can't find anyone to chrome the shroud. Should be ready by the MACC show on May 5th at Costco in Hoover. How's that for a free plug! MACC does a great job with that show and I am very excited about being there. Heard a rumor that your are going to be selling homemade ice cream. It's going to be great!
See you there!
Slik
Old Mar 26, 2007 | 10:46 PM
Z0SLIK's Avatar
Z0SLIK
Thanks guys for all the help!
Old Mar 27, 2007 | 11:03 AM
BudgetPlan1's Avatar
BudgetPlan1
I think this write-up has some pics of removing fan shroud
http://www.conceptualpolymer.com/Rad...op%20inst..pdf
Old Mar 27, 2007 | 01:48 PM
5ltrEATER's Avatar
5ltrEATER
Good info in this thread... I'll be doing this in the near future!
Old Mar 27, 2007 | 03:27 PM
Red Thunder 03's Avatar
Red Thunder 03
Great info from Budget plan, I too am looking at this mod in the future.
To Removing Fan Shroud?
