Thin Spokes
Old Mar 26, 2007 | 09:15 PM
bscottb's Avatar
bscottb
Default Thin Spokes
How do you remove the center caps on thin spokes? I don't see any identations where you would pry them off. Do you have to remove the wheels to remove the center caps? Mine are all loose and rattle. I was wondering if they could be tightened, maybe bending the tabs like on old hubcaps.
Old Mar 26, 2007 | 09:21 PM
Blown 346's Avatar
Blown 346
They cant be tightened, you may break the plastic tabs that hold them on. You should just be able to push them, if that doesnt work you might look into getting new ones.
Old Mar 26, 2007 | 09:45 PM
Johnny Hardcore's Avatar
Johnny Hardcore
Can you hear them rattle when you drive, or do they rattle when your detailing the rims?
Take the lock nut screw cap off and use a flathead screw driver to pry it off. It should pop off relatively easy for you.
I purchased a cheap set of center caps on line, with the C5 emblem for about $30. They look and fit perfectly, a little rattle when detailing the rims.
Old Mar 26, 2007 | 10:00 PM
bscottb's Avatar
bscottb
I can hear them when I start off. They rattle and feel way loose when detailing wheels.
Old Mar 27, 2007 | 05:38 AM
Blown 346's Avatar
Blown 346
Sounds like your going to have to repalce them. The little plastic tabs that hold them against the wheel are most likely broken and wont let it get the snug fit they should.
Old Mar 27, 2007 | 06:44 AM
dadvan99's Avatar
dadvan99
Cruise-In VII Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Oldtimer
I put some electrical tape on the tabs and now have a snug fit without any rattle.
Old Mar 27, 2007 | 06:57 AM
steve8's Avatar
steve8
This should work. Certainly beats buying new ones.
Old Mar 27, 2007 | 07:16 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Mar 27, 2007 | 07:25 AM
Tigershark3's Avatar
Tigershark3
I've got one that's like that. All I did was take it off and wrap some duct tape around one of the tabs. (hey it's hidden anyway). This helped hold it on. El cheapo but effective fix.
Old Mar 27, 2007 | 12:41 PM
Sillyme's Avatar
Sillyme
Take them off and put some silicone seal on the mounting tabs then install the cover back in the wheel. You will be surprised how well a gob of silicone can hold something, and it can still be removed later if needed. I have done this on center caps of my pickup wheels. They used to make noise, now they are completly quiet.
Old Mar 27, 2007 | 12:46 PM
jrose7004's Avatar
jrose7004
Most of mine you can just get a hold of them and pull them off. Every now and then I get new ones on E-Bay and throw the old ones away. They're cheap.
To Thin Spokes
