build codes?
Old Mar 27, 2007 | 02:05 AM
sla07's Avatar
sla07
Default build codes?
anyone know what U-9567 code means? Thats the only one I cant find...
would anyone be able to tell me what these build codes are?...i was able to find a few of them searching through the forums but it was only about 1/4 of them if that...or if there is a site i can just punch these in i can do the work myself....just not really sure where to even look....
Factory Build Codes: 1999 Chevrolet Corvette
AAB
AG2
AK5
AQ9
BGR
B34
B84
CC3
CJ2
DLS
DL8
D42
FEI
FE9
G90
G92
IL3
JL9
K63
LSI
MX0
M30
NF2
NK4
QD4
T96
UN0
UV7
UZ6
U52
VM3
V49
V73
XGG
YGH
1AY
1SA
10U
921
923
U-9567
Old Mar 27, 2007 | 02:26 AM
sla07's Avatar
sla07
crap i feel dumb....found them....
http://forums.corvetteforum.com/show...ht=build+codes
A4G Override Option of Canadian Requirement
AAB Memory, Driver Convenience Package
AG1 Power Driver Seat (Hardtop)
AG2 Power Passenger seat
AK5 Inflatable Restraint System, Front Seat, Driver and Passenger
AN4 Restraint Provisions, Child
AP9 Parcel Net (Hardtop)
AQ9 Sport Seats
AR9 Base Seats
AX4 Conversion, Seat Belt, European
B3R Package, Interior Sport *Note 1
B34 Mat Covers (Floor Mats)
B4H Modification, Noise Control, Export
B84 Body Side Moldings
BAG Loose Parts Bag, Export
BCC Cylinder Unit Passenger Door
BGR Bowling Green Plant Processing
C2L Dual Removable Roof Panels (CC3+CF7) (Coupe)
C60 HVAC System, Air Conditioning, Manual Control
CC3 Removable Roof Panel, Blue Tint (Coupe)
CF7 Removable Roof Panel, Nontransparent (Coupe)
CJ2 HVAC System, Air Conditioning, Automatic Control
European Exports
from Manny Jägerfeld Corvette Magasinet
"Most European stock orders, and blind stock, will have CT1,
since the GM import harbor and enormously huge 'stock ware houses'
are in Antwerpen in Belgium. Every third car has it over here,
besides those actually ordered for customers in Belgium."
"Those actually ordered in Belgium are mostly ordered NOT by
Belgians but rather by other European national officials working
within the EEC government in Brussels. They have some tax-free deal there.
When they go home after their legislated period of time the car will
eventually end up in the respective country, as la France, Germany, Sweden
and all the others."
"Many of these will end up in the States likely one day, its just a matter of years."
CT1 Country Code, Belgium (Export)
CT2 Country Code, Austria (Export)
CT3 Country Code, Germany (Export)
CT4 Country Code, Luxemburg (Export)
CT5 Country Code, The Netherlands (Export)
CT6 Country Code, Italy (Export)
CT7 Country Code, Denmark (Export)
CT8 Country Code, Portugal (Export)
CT9 Country Code, Spain (Export)
CU1 Country Code, Norway (Export)
CU2 Country Code, Finland (Export)
CU3 Country Code, France (Export)
CU4 Country Code, Sweden (Export)
CU5 Country Code, Switzerland (Export)
CU7 Country Code, Kuwait (Export)
CU8 Country Code, Saudi Arabia (Export)
CU9 Country Code, England (Export)
CV1 Country Code, Iceland (Export)
CV3 Country Code, Mexico (Export)
CV5 Country Code, Japan (Export)
CW2 Country Code, Gulf States (Export)
CO5 Roof, Convertible Folding
D28 Mirror, Outside, Rearview, Delete
D42 Luggage Shade(Coupe)/Parcel Net
DD0 Electrochromic Mirrors - Outside
DD8 Electrochromic Mirror - Inside
DL5 Decal, Roadside Service Information
DL8 LH/RH Heated Sport Mirrors
E45 Cover, Convertible Top, Protective
EXP Export, N.A.E.S.
F45 Chassis, Selective Real Time Damping
F55 Continuously Variable Electronic Real Time Damping Suspension by Delphi (Whew!)
FE1 Base Suspension
FE3 Suspension System, Sport (part of Z51)
FE4 Suspension System, Z06
FE9 Certification, Federal Emission
FFS Revised Fuel Tank System (2003/2004)
G90 Axle, Rear, 3.15 Ratio
G92 Axle, Rear, Performance Ratio
GU2 Axle, Rear, 2.73 Ratio
GU6 Axle, Rear, 3.42 Ratio
IL3 Trim, Interior Design(L3) (Base w/AQ9)
IL4 Trim, Interior Design(L4) (Z4Z - 1998 Indy Pace Car)
IP3 Trim, Interior Design(P3) (Base w/AR9)
IP4 Trim, Interior Design(P4) (Hardtop/Z06)
JAG ABS Location
JL4 Active Handling system
JL9 Brake System, Power, Front & Rear Disc, Antilock
K63 Generator 110 Amp
KG3 Generator 145 Amp - This was, at first, believed to be misspelled K63, but it is a valid code.
K05 Heater, Engine Block (Canada)
K29 Module, Powertrain Control (Non-OBD II, Unleaded)
KDR Special Handling, Delivery
LS1 Engine, Gas, 8 Cylinder, 5.7L SFI Alum (VIN G)
LS6 Engine, Gas, 8 Cylinder, 5.7L SFI Alum 385 hp (w/2001 RPO Z06)
M12 Transmission, Manual 6-speed,(part of RPO Z06)
M30 Transmission, Automatic, 4-speed, 4L60-E, Electronic
MAE Marketing Area, Europe
MAG Marketing area Gulf State organizations
MAU Marketing Area, Unregulated
MM6 Transmission, Manual 6-speed, Borg Warner
MN6 Merchandised Transmission, Manual 6-speed Provisions
MX0 Merchandised Transmission, Automatic O/D Provisions
N37 Steering Column: Power Telescope Man. Tilt
N73 Wheels, Custom Sport, Magnesium
NA3 Emission System, Japan
NA7 Emission System, European
NB6 Emission System, California, Tier 1
NB8 Emission System, CA/Northeast Emission Override
NC1 Emission System, California, LEV
NC7 Emission System, Unleaded Fuel(Export)
NF2 Emission System, Federal, Tier 1
NF7 Emission System, Federal, Label
NG1 Emission System, Northeastern States
NK4 Steering Wheel, Sport Leather
NM2 Emission System, Export, Leaded Fuel
NM8 Leaded Fuel System, Compatible
NN5 Emission Overide, California System, Federal Offset Vehicle
NP7 Steering Column, EEC Approved
NT3 Emission System EEC 00
NV7 Steering, Power, Variable Effort
P12 Wheel, Painted (Z06)
PA6 Wheel, Styled, Painted
QD4 Standard Aluminum Wheels
QG1 Standard Aluminum Wheels (new style mid year 2000)
QE1 Aluminum Wheels (Z06)
QF3 Wheels, 17x8.5 Front + 18.0x9.5 Rear Aluminum, w/ Special Offset
QF5 Polished Aluminum Wheels
R6M New Jersey Cost Surcharge(Req'd in New Jersey)
R7A Control Sales Item 26 Processing Option
R7C Dealer Authorizes Order Release (no further changes)
R7K Control Sales Item 36 Processing Option
R8C National Corvette Museum Delivery
R8T Control Sales Item 69 Processing Option
R9U Control - Sales Item #95
R9Z Control - Sales Item #100
RPA Rear Parking Assist
SLL Order Modification Orders Sold(replaced 1AZ, circa 2001)
SLM Stock Order Processing Code(replaced 1AY, circa 2001)
T62 Light, Daytime Running - Delete
T82 Headlamp Control, Automatic on/off (Twilight Sentinel)
T84 Headlamps, RH Rule of Road
T85 Headlamps, LH Rule of Road
T89 Lamps, Tail, Stop & Turn, Export
T90 Lamps, Signaling & Marker, Front
T93 Lamps, Tail, Stop & Turn, Special
T96 Lamps, Fog
TR9 Lighting Package (Hardtop)
U1S Changer, Remote Compact Disc
U19 Instrument Cluster, Metric (Canadian, Export)
U52 Instrument Cluster, Electronic
U73 Antenna, Fixed, Radio (FRC)
U75 Antenna, Power, Radio (Convertible)
UD4 Overspeed Warning, 120 km/h
UK1 Radio Frequencies, Japanese
UL0 Radio, AM/FM Stereo, Cassette (Base Radio MY1997 - MY2001)
UL2 Radio Frequencies, European
UN0 Radio, AM/FM Stereo, Compact Disc(Base Radio MY2002)
UQ5 Speaker System, 4, Dual Front Door, Dual Quarter Mounted
UV6 Display, Heads Up
UV7 Windshield Antenna
UZ6 Speaker System, 6, Quad Front Door Mounted, Dual Quarter Mounted
V41 Kit Accessory
V49 License Plate Frame, Front
V73 Vehicle Statement, US/Canada
V76 Tow Hooks
V78 Vehicle Statement, Delete
V87 Vehicle Statement, Gulf States
VB1 Label, Shipping, Japan
VC5 Label, Shipping, Except US/Japan
VD1 Provision Options, Europe
VE1 Provision Options, Japan
VE3 Label, Battery Disposal
VG1 Protector, Transit Coating, Underhood
VG6 Label, Information - Bumper Impact
VG8 Label, Information - Notice to buyer, Emissions
VG9 Protector, Transit Coating, Exterior Body
VH5 Plate,Vehicle Identification
VL4 License Plate Mounting Package, Front, EEC
VL7 Bumper Impact Information Label (NY state)
VM3 Label Information, consumer contains BPR IMP Standard
VT1 Document EEC Certification of Conformity Europe-Russia-Japan(used 1997-98)
"WD Codes"
Reserved for future model year vehicles built during current year's production. Also known as "alpha", "beta" and "pilot" cars.
WD1 "Pilot Vehicle"
WD2 "Factory Prototype"
WDO "Containment Vehicle"
XFW Tire, Front, P265/40R17 (Z06)
XGG Tire, Front, P245/45ZR17 BW TL SBR HW4, EMT
XMC Tire, Front, P245/45ZR17 BW TL SBR HW4
YF5 California Emissions
YFU Tire, Rear, P295/35R18 (Z06)
YGH Tire, Rear, P275/40ZR18 BW TL SBR HW4, EMT
YME Tire, Rear, P275/40ZR18 BW TL SBR HW4
Z06 Merchandised Pkg.,(1YY37) Special Performance Hardtop
Z4Z Merchandised Pkg., Indy Pace Car
Z19 Performance Package
Z25 50th Anniversary Package(2003)
Z31 Price Sheet Advance, Processing Option - Canadian
Z49 Modifications, Canadian, Mandatory Base Equipment
Z5X Mirror Provisions, Arabic Language
Z51 Performance Package, Handling
ZR6 Special Unit - Show Car
ZCA Engine Suffix code: LS6-Manual M12 Transmission
ZCB Engine Suffix code: LS1-Automatic Transmission
ZCD Engine Suffix code: LS1-Manual Transmission
Old Mar 27, 2007 | 03:35 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
To build codes?
