Changing Belts / Hard Hard
Old Mar 27, 2007 | 04:08 PM
DADEO1's Avatar
DADEO1
Default Changing Belts / Hard Hard
I know there are mant threads on this, but on a scale of 1 to 5.
Five being the hardest. ( like the little wrenches in Vette Fever Magazine )
How hard is it to change out the belts ?
Any special tricks ?
Old Mar 27, 2007 | 04:10 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Not too bad at all. Its about 1 for me on factory setup (but that varies )
Use Goodyear Gatorback belts. They are the best.
BTW, with my current setup, changing belts is almost a 10
Old Mar 27, 2007 | 04:15 PM
joshscalf's Avatar
joshscalf
I'd say a 1 as well. It's not that it's that hard, it's just that it's a slight PITA if you've got remotely big arms and the car is still hot.
Old Mar 27, 2007 | 05:10 PM
BanditDude's Avatar
BanditDude
Drive it up on ramps and it won't be too hard. I'm another one w/ big hands that took a bit longer to get the job done.
Old Mar 27, 2007 | 05:16 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Not hard at all, especially if you have somebody to help hold and keep them lined up on the opposite side.
These might help:
94legaleagle's Avatar
94legaleagle
requires a 15mm socket or wrench to put pressure on the idler pulleys
put it up on ramps or jackstands - once that's done, the A/C belt might take 5 minutes, if you are slow - the main belt should take you all of 3 minutes if you take your time
Old Mar 27, 2007 | 05:17 PM
mcmtac14's Avatar
mcmtac14
has anyone changed the pulleys at the same time.... It looks like the large one on the crank shaft has a slight wobble to it. It makes a loud squeel for the first 10 minutes of driving.... any tips, reccomendations!!
thanks all!
mcm
Old Mar 27, 2007 | 07:27 PM
Jboger2K's Avatar
Jboger2K
I changed the main idler pulley and the AC tensioner. Idler is easy. The ac tensioner took me way too long. Ramps, as posted above would have seriously simplified the job. Better done from underneath. It would be helpful to have someone hold the AC belt in place at the harmonic balancer. I had to stic a breaker bar in to hold it in place. Great post of belt drive assembly etc. I could have used that!
FactoryRaceCar
thanks all!
mcm
Now thats a 10 right there!
Old Mar 27, 2007 | 07:41 PM
rws.1's Avatar
rws.1
it is a 1...
20 minutes start to finish changing both belts.
here is a link to a post with some tips...
see my post within the link for two other links...
Old Mar 27, 2007 | 07:45 PM
FactoryRaceCar
Originally Posted by rws.1
it is a 1...
Buddy you forgot to post the link(s)
Old Mar 27, 2007 | 11:13 PM
mcmtac14's Avatar
mcmtac14
please post the link! I have this picture of me on the garden state parkway with the belts blown off!!!!
thanks all!
MCM
Old Mar 27, 2007 | 11:23 PM
z06Bigbird's Avatar
z06Bigbird
thanks all!
MCM
Quit blocking traffic. I am trying to get to beach.
Ed
Old Mar 27, 2007 | 11:35 PM
mcmtac14's Avatar
mcmtac14
it's bumper to bumper and I am pushing as fast as traffic si going
To Changing Belts / Hard Hard
