run flats
Old Mar 28, 2007 | 08:24 PM
robsciam's Avatar
robsciam
Default run flats
hi. i have a 2001 z06, does this car come with run flats, and if i change the rear tires to something non run flat what will happen, will it be just a light in the dash? the car is not daily driven so what is a better wat to go?
Old Mar 28, 2007 | 08:27 PM
Oldvetter's Avatar
Oldvetter
Z06s did NOT come OEM with runflats or tire pressure sensors. You can install them. They came with a tire inflation/sealer kit (pressure can).
Old Mar 28, 2007 | 08:47 PM
robsciam's Avatar
robsciam
thank you. i didnt realy want them, i just wanted to change 2 a stickier tire, i dont drive the car daily or that far from home.
To run flats
