[Z06] help please
Old Mar 28, 2007 | 11:19 PM
whtgt02vert's Avatar
whtgt02vert
Default help please
trying to take off my stock ti. exhaust how the heck do you get the tube to go over the axle? any help please
Old Mar 29, 2007 | 07:58 AM
bb609's Avatar
bb609
The rear end must be at least 36" off the ground so you can swing the whole thing under the axle to clear it. Also, did you drop your sway bar? That's needs to be moved out of the way too (not the ends, just the mountings).
Old Mar 30, 2007 | 05:31 AM
boerio's Avatar
boerio
Yes ... remove the four bolts holding the sway bar to the transaxle housing. You don't need to take the sway bar off the end links. You will be able to move the bar out of the way so that the exhaust will clear as you pull it out.
Jeff
To help please
