will this work ??
Old Mar 29, 2007 | 09:50 AM
elctroman's Avatar
elctroman
Default will this work ??
ok i'm having a draing of the battery problem and dealer can't find it unless it happens when the are checking it .i hear a noise from the right side dash when it goes dead but normally the battery is almost dead by the time i get in it .after i jump it the noise goes awayi was wondering if i do hear it next time can i start pulling fuses till it goes away then that will tell me whats draining the battery?
Old Mar 29, 2007 | 09:56 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
That certainly is a possibility! It should not hurt anything.
Just remember when you pull fuses, for instance your Radio fuse you might have to reset the factory code if it gets locked!
It might give you the circuit and you can trace the culprit from there.
Does it sound like the fan motor or clicking humming this might help so you can look at the fuse circuits and go after those specified fuses first!
Just a thought. Let us know what you find!
Thanks,Matt
Old Mar 29, 2007 | 06:26 PM
elctroman's Avatar
elctroman
dont think it is a fan or motor ,last time i got out i made sure the seats were not to far back and the radio,ac,fan controls ,radar dector was either turned off or unlpugged all doors shut and no lights on
To will this work ??
