I cant get into the shop for 3 more days to get my oil changed my 97 is a daily driver and its saying I have 3% oil life can I make it till then or am I risking serious damage to my engine. The oil level itself is okay
Don't sweat it. That's just an indication the the oil should be changed - not that it will implode your engine. You have plenty of time to get it changed and 3 days won't make much difference as along as you don't drive to LA and back.
You're just fine, I've hit 0% and kept going another 2 or 3000 miles and the oil analysis results came back looking great.
Another thing to keep in mind is that the oil life monitor in the 97-00s will count down faster than the ones in the 01-04s. This is because the OLM on the 97-00s was calibrated for a maximum interval of 10k, while on the 01-04 it's 15k.
The DIC is just a suggestion. I ran Mobil 1 synthetic in my toyota and changed it every 12000 miles, just about when it STARTED to look dirty.
I'm positive you will be fine with a couple (hundred, if not thousand) miles past 0%. Just look at the oil, if it looks like honey (color) you got a long ways to go.
Granted, mine is a daily driver and mileage is predictable. If you track the thing, then you should change it quite a bit more.
You'll be fine. Btw if you can stand possibly extending your drain interval do an oil analysis. You may find you can go quite a bit longer in between oil changes.
I drove for awhile at 0% then got tired of the warning, so I reset it and am now down to 83%. Hopefully I will have time to change it soon, but the car hasn't melted yet...
