when I attempt to put my profile picture on I get a forum message that states the download failed-even though the picture is under 39kb. Any suggestions?
SeaLawyer-if I wanted comedy I'd tune into Leno. I would like to post a picture of my car as it appears under my forum name. It shows under picture profile but will not transfer. Under the help section it gives advice on posting a picture under your thread I just want to find out why the profile picture fails when I make a post? Any real suggestions?
And please-can the comedy or sarcasm-if you can't help with a answer don't reply.
Dude, take a deep breath and chill out and then take a chill pill while having a beer... sheesh.
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
It's not the size in kb that's getting you its the pixel size (640x480). The Help section gives you max size. Reduce it and try again. It took me a while too.
This may not be the case but i had the same problem when I originally tried. My problem was trying to name the picture "avatar" because I was using it as an avatar. It worked once I changed the name.
I was just playing... I guess he's having a bad day or something. If I'd known the solution, I would have posted it. I knew others would chime in and help... Oh well.
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
I think you might be confusing the avatar with a profile picture. If you want to show this pic when you post, paste it in your "avatar" not your profile.
More comedy
SeaLawyer was attempting to assist - don't get your panties in a wad - take a
