Fast 1/4 miler C5s
Old Mar 31, 2007 | 10:16 AM
snaponjackson's Avatar
snaponjackson
Default Fast 1/4 miler C5s
I have a 600 RWHP C5, but run consistant low 11 sec. 132 MPH times.
Give me some ideas. Everybody tells me I can go mid 10's. Maybe I/m
not hooking hard enough?
Old Mar 31, 2007 | 10:23 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
ccw drag pack
Old Mar 31, 2007 | 10:41 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
it sounds like you could benifit from a rear end swap. What are you runing back there now?
Old Mar 31, 2007 | 10:49 AM
JPM@AutoBuffs's Avatar
0JPM@AutoBuffs
Former Vendor
From: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
S. Jersey Events Coordinator
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
Do you still have a stock butt?
Old Mar 31, 2007 | 10:52 AM
snaponjackson
I have 4.10:1 gears , hardened output shafts, stage 3 spec clutch
Old Mar 31, 2007 | 11:00 AM
Mike Mercury's Avatar
Mike Mercury
what are your 60' times?
with all that HP; once hooked up - you have the capability to be in the 10's. I suspect the hold-up is in the launch.
Old Mar 31, 2007 | 11:31 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
it sounds like somhow you're not getting the HP to the ground.
Old Apr 1, 2007 | 04:46 AM
vetterlatethannever's Avatar
vetterlatethannever
60' times may be the key.
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Originally Posted by Stangkiller
ccw drag pack
Old Apr 1, 2007 | 09:26 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
What he said
Old Apr 1, 2007 | 10:22 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Yes should be in the 10's not hooking up I bet 60' times are slow 1.90--2.20
I have an A4 98 cam and heads car 390 RWHP and it runs 11.90's with street tires
Old Apr 2, 2007 | 05:39 PM
Blue Angel's Avatar
Blue Angel
I went 11.86 @ 118 on the stock GoodYear F1SC tires with a stock with headers '02 Z that dynoed at 360 RWHP. That was with a 1.82 60' time.
Get your launch figured out. If you're trapping 130+ you've got alot left in the car. A scanned timeslip and more detail about your car and mods would help others tell you what was up with your runs.
Old Apr 2, 2007 | 06:27 PM
Corvette Don's Avatar
Corvette Don
What else was done?
Old Apr 2, 2007 | 10:09 PM
Whiteonrice's Avatar
Whiteonrice
Your 60s are where it's at. Your just not hooking up good enough. At 132 you sure have the power.
Rick
To Fast 1/4 miler C5s
