engine cleaning question
Old Apr 9, 2007 | 12:14 AM
RWVH's Avatar
RWVH
Quote from Simple Green web site :
Aluminum - Is it safe to use Simple Green on aluminum?
Simple Green products have been successfully and safely used on aircraft, automotive, industrial and consumer aluminum items for over 20 years. However, caution and common sense must be used: Aluminum is a soft metal that easily corrodes with unprotected exposure to water. The aqueous-base and alkalinity of Simple Green or Crystal Simple Green can accelerate the corrosion process. Therefore, contact times of All-Purpose Simple Green and Crystal Simple Green with unprotected or unpainted aluminum surfaces should be kept as brief as the job will allow - never for more than 10 minutes. Large cleaning jobs should be conducted in smaller-area stages to achieve lower contact time. Rinsing after cleaning should always be extremely thorough - paying special attention to flush out cracks and crevices to remove all Simple Green/Crystal Simple Green residues. Unfinished, uncoated or unpainted aluminum cleaned with Simple Green products should receive some sort of protectant after cleaning to prevent oxidation.
Old Apr 9, 2007 | 09:46 AM
dankhts's Avatar
dankhts
I usually just use Simple Green or a similar product, then just hose it down. After it dries, I usually spray it with either Armour All, or No Touch Tire Shine (better) and it looks great till next time.
Old Apr 9, 2007 | 10:09 AM
bigjohn23's Avatar
bigjohn23
Read on the net, spray motor down with Gunk, rinse off with water, spray with armour all tire spray, try it on my Jeep and under the hood look like it was brand new, have not try it on vette.
