I'm changing the wheels on my 02 Z. I'm going with z06 non-motorsport wheels in black with a polished lip. 19 front with 265/30/19 toyo proxy 4, And 20 rear 295/30/20 toyo proxy 4. Are these the correct size tires? There isn't much of a choice when it comes to 20" rear tires but the toyo's come as close as i think is good.
Your fronts are right on and your rears are a little less than 1" larger than stock. I am running 295/35/19's in the rear, which are almost the same diameter as 295/30/20's and other than the speedometer reading a little slow, I haven't had any issues.
