need help!!!! car not shifting right
Old Apr 2, 2007 | 06:29 PM
omarcoolguy's Avatar
omarcoolguy
Default need help!!!! car not shifting right
delete
Old Apr 2, 2007 | 06:32 PM
Blown 346's Avatar
Blown 346
Sounds like the trans was just low on fluid.
Old Apr 2, 2007 | 06:51 PM
omarcoolguy
yah well i got it flushed and filled this mouning.;.....its not right......do u guys think it has something to do with the used chip
Old Apr 2, 2007 | 07:15 PM
Norris's Avatar
Norris
First thing I would do is confirm the transmission is topped off. car has to be running and in drive to properly check the fluid level. Also ensure the transmission fluid is warm.
Old Apr 2, 2007 | 07:18 PM
11yellowgscpe's Avatar
11yellowgscpe
Did you reprogram after putting in the chip, if not reprogramming must be done.
Old Apr 2, 2007 | 07:56 PM
QwkSlvrZ06's Avatar
QwkSlvrZ06
What kind of "chip" did you put in? The PCM in your car is re-flashable, but I wasn't aware of any "chip" that can be installed. Shed some light on this "chip" and maybe we can offer some help.
Old Apr 2, 2007 | 11:40 PM
omarcoolguy
i dont think its the chip now.......i took it out and its doing the same thing.....it was a JET chip...that was out of another vette.....its suppose to be preprogrammed....so u cant do any thing to it....any way.....its still not shifing right....im going to take it back to jiffy lube tomarrow and have them make sure its topped off.....i think they didnt know what they were doing......how do u know its topped off???? and is there any electrical issues that could be the problem?
Old Apr 2, 2007 | 11:58 PM
omarcoolguy
any help?????????
Old Apr 3, 2007 | 01:12 PM
Mike McCoy's Avatar
Mike McCoy
I responded yesterday but it didn't get posted. To check the fluid level in an A4 follow these important steps. Car must be raised and level. Engine must be running and in transmission in Park. Transmission fluid must be warm. The fliud level is correct when ATF is at the lower edge of the upper fill plug hole. Replace the plug before turning off the engine, or hot oil will pour out of the hole. The transmission fluid pump draws the ATF level down when it is runnig. This is the ONLY way to confirm fluid level.
Old Apr 3, 2007 | 01:19 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
If it's not the fluid level (once you have it checked) it might be that chip you put in... the only way I know to adjust shift points is by using a LS1 edit program, or a hand held tuner like Predator or Hypertech. I have never heard of a chip being used.
Good luck getting it fixed
Old Apr 3, 2007 | 01:31 PM
omarcoolguy
i just took it to jiffylube......they didnt check the fluid right......it was about 1 1/2 qurts or 2 low......and they filled it back up and its still not right....the owner of the place made some phone calls and is taking it to a mechanic is know vettes well hes gonna put it ona scan stool and see if its a sensor or something on it.....but he said he doesnt think the trans got damaged........is it there fault?
Old Apr 3, 2007 | 01:42 PM
VinnyT's Avatar
VinnyT
Yes, but good luck proving it. There was another thread with the same problem. Bottom line is that they screwed up the tranny and is liable for the repair. Hopefully the manager will make good on it. But, sounds like the tranny is now toast.
Old Apr 3, 2007 | 02:14 PM
omarcoolguy
ya well im still waiting for the phone call....its like im waiting to see if my car is dead or gonna make it
Old Apr 3, 2007 | 03:12 PM
tellefan's Avatar
tellefan
This is why I do all of my oil changes and trans changes. I hope they repair it for you. David
Old Apr 3, 2007 | 04:40 PM
Norris's Avatar
Norris
Mike, I thought after placing the vette on the lift, the engine must be running and the transmission in drive. I could be wrong, however.
Old Apr 4, 2007 | 11:59 AM
omarcoolguy
srill havente heard from the owner at jiffy lube ....should i call him
Old Apr 4, 2007 | 05:06 PM
dano99vert's Avatar
dano99vert
St. Jude Donor '13-'14-'15-'16
Default Trans fried
I was the one who just went thru msame problem, see thread Bad deal at dealer going to cost me$$$$$, Any way my trans was left 1 1/2 qts low at chevy dealer after service and it fried the 3/4 clutch pack in trans, Chevy did not assist and took no liabilty, I just had trans rebuilt at independent cost me 2400.00, Think I am taking to small claims?, car only had 20k miles on it. Im at work right now dont know if i will be able to post back, but this sounds like what i just went thru / nightmare!!!!!!!
Old Apr 4, 2007 | 05:17 PM
JLA's Avatar
JLA
www.jiffylubeproblems.com/Experiences426-450.htm
To need help!!!! car not shifting right
