Redline's Fuel System Cleaner. Extremely potent and unlike techron, which is just simple alcohol/kerosene combinations which a lot of injector cleaners are.
Redline as well as Lucas Fuel Injector Cleaner (Tune-Up In a Bottle), in conjunction with an injector cleaner, it also has a lubricant that will help lubricate fuel pump bearings, and also will help lubricate piston rings.
Found this is a Tech area and was wondering just how good the Redline is and if anyone uses Lucas.
I've used the RedLine many times. In fact, I just used it to "clean up" the gas gauge on my '96 Camaro. The gauge was reading way over full the last time I started the car up. (Winter storage) Poured a little RedLine in the tank, bounced the back bumper up and down a couple of times to stir things up, hit the key, PRESTO!! Gas gauge read 5/8, just like it should have.
The alcohol/kerosine is not the key component in any fuel system clenaer, the detergent package is. Alcohol and kerosene alone will not clean up combustion chamber deposits.
Personally, I prefer the Valvoline Synpower fuel system cleaner, or SeaFoam.
I have never seen a comparison of cleaning power among major brands.
I've been using the AMSOIL PI for years, in all my vechicles. So far have avoided having problems.
Treated Fuel Delivers Maximum Performance
AMSOIL PI is the most potent gasoline additive available today. As a concentrated detergent, it is unsurpassed in cleaning combustion chamber deposits, intake valve deposits and port fuel injector deposits. AMSOIL PI helps maintain peak engine efficiency, fuel economy, power and drivability in newer low mileage engines.
My brother-in-law is a dealer for an Auto Parts store and he said to try Dragon's Breath by Castle Chemicals... it's supposed to be hands down the $HIT!
