ignition switch going
Old Apr 4, 2007 | 11:28 PM
newyorknick's Avatar
newyorknick
Default ignition switch going
stick the key in and turn it and sometimes nuthin.....jiggle the key a bit and startup occurs....could the ignition switch be going bad....the battery is new and connections are all in goor order...weather or moisture not a factor. thanks for any responses.
Old Apr 4, 2007 | 11:38 PM
happa's Avatar
happa
Look behind the ignition switch. There are 2 white wires, one of them may be broke or barley hanging on. Mine was broke and did the same thing yours is doing. Hope this helps, Good Luck!
Old Apr 4, 2007 | 11:43 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Check for dirt on the key.
To ignition switch going
