Coupler reducer
Old Apr 5, 2007 | 11:57 AM
slvr bulit's Avatar
slvr bulit
Default Coupler reducer
I installed the Callaway Honker and gave my friend my old k/n dual cone set up. The problem is my car is a 98 and his is a 01. The rubber piece from the filters that goes to the mass air flow sensor is too small on the mass air flow sensor side, does any make this coupler with a bigger end on one side?
Old Apr 5, 2007 | 12:49 PM
hotwheels57's Avatar
hotwheels57
Take the OD measurements (calipers work the best) of what you need at both ends of the coupler. Then do an internet search using the search keywords silicone coupler. You can do the same on EBAY. You'll find many sources for the reducing couplings, usually through vendors who deal in turbo chargers.
Old Apr 5, 2007 | 01:28 PM
slvr bulit's Avatar
slvr bulit
Thanks Hotwheels
Old Apr 5, 2007 | 02:14 PM
brandtdavis's Avatar
brandtdavis
I would check the local hardware stores too. They have couplers sometimes if you need it fast while you order one from online.
To Coupler reducer
