Is this a common problem?
Old Apr 6, 2007 | 06:41 AM
Black 'n Tan's Avatar
Black 'n Tan
St. Jude Donor '07
Default Is this a common problem?
My door panel is "de-laminating"!!!! I was wiping the interior down yesterday and I noticed that the area where you rest your arm on the driver's door is "disappearing". The vinyl that should be glued to the door panel is releasing, causing the "shelf" where you rest your arm on the door to disappear! I notice it is in the beginning stage on the passenger door. I still have 700 miles left before my warranty ends, anywhere else should I look? BTW, my car is an '04 with 35K on the clock.
John
Old Apr 6, 2007 | 07:13 AM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
Yea. My car was doing it. I bought some used door panel for Gene's Karshop. I would take it in and see what the deeler can do
Old Apr 6, 2007 | 07:24 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
John
I would hustle to the dealer and have them replace the panels
Old Apr 6, 2007 | 07:46 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Good advice here Joe
Old Apr 6, 2007 | 07:54 AM
I have heard of this happening before. You can try and get the dealer to replace the panel under warranty. Another option would be to get a set of the arm rests from Vette Essentials. They are very comfortable and will cover this area.
Old Apr 6, 2007 | 08:25 AM
Black 'n Tan
St. Jude Donor '07
Thanks guys, sounds like it is not that widespread a problem, so if I get new ones they should hold up. My car came from Florida, my guess is it was stored outside, it has it's own garage bay now, so it won't be sitting in the hot VA Summer sun. My console cover feels mushy under my arm as well, but that I'll probably re-cover with one of those after market leather embroidered covers. I'm kinda disappointed in GM, this is a top-shelf car, upon initial inspection it looks very well made, but my past experience with GM has shown after about 3 years, shoddy materials start showing up. Geeze! If they only spent about $250 per unit (I'd gladly pay that) to put better materials in their cars, they could easily re-coup a hunk of market share.
I love the power and fuel economy of my 5.7L, (I averaged 32 coming back from Florida) but the engine sounds noisy as hell till warm. The Ford modular engines are SUPER QUIET, (I've had 5, 4.6's and 5.4's) they idle silky-smooth, cold or hot, and the only noise you hear with the hood up is the ticking of the injectors. I hope GM some day will finally get it, and go that little extra to make world class products. This '04 'Vette is telling me it's still business as usual, sigh. I WANT TO BELIEVE!
John
Old Apr 6, 2007 | 09:12 AM
LTVetteVert00's Avatar
LTVetteVert00
John
I do think this problem may be more prevalent than you might think. Mine is doing the same thing. Too bad there is not a way to inject glue behind the thing and force it to reattach to whereever it was designed to attach? It is curious that it seems to occur on driver side only? At least that is my experience.
LT
Old Apr 6, 2007 | 09:26 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
After you get it fixed I would install the arm rest pads that Vette Essentials sells - not only will they cut down on wear and tear, they are really comfortable
Old Apr 6, 2007 | 09:55 AM
o2z51's Avatar
o2z51
Thats a very common problem, when I was looking at used vettes quite a few had the same problem, as far as a well made car the vette is not, most of the interior materials are cheap and put together cheaply, like the door panels and seats but I still love them
Old Apr 6, 2007 | 09:56 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Warranty you have! Use it before it is too late!
Thanks,Matt
Old Apr 6, 2007 | 12:54 PM
VetteBandit's Avatar
VetteBandit
How do the vette essential arm rests install?
Old Apr 6, 2007 | 01:02 PM
brookman's Avatar
brookman
Is there actual padding in theirs? The stock one makes my elbow hurt.
Old Apr 6, 2007 | 01:50 PM
ksg32198's Avatar
ksg32198
John
Take it to the dealer. I had both of mine on my 04 Z06 replaced under warranty recently because of that exact same issue. If your barely out of warranty, they should still do it. If they have any issue with it, let me know and I will send you my invoice so they can see that mine was replaced for the same thing.
Old Apr 6, 2007 | 02:48 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
YES, that's the exact reason I added them to my car. Picture below is not the best (was intended to highlight my reflector mod), but you get the idea.
Old Apr 6, 2007 | 03:54 PM
Black 'n Tan
St. Jude Donor '07
Thanks guys for all the info. If the 'Vette essentials armrest insert screws through the panel, it would be the cure for the delamination problem. (it would hold it in place) If it attaches with adhesive, wouldn't it ride up with the vinyl underneath?
John
Old Apr 6, 2007 | 03:59 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Apr 6, 2007 | 04:58 PM
rgtkst's Avatar
rgtkst
RUN FOREST RUN !!!!!!
ghet in before you are out of luck. new ones are kinda spendy and it happens alot. have my own bubble on the driver side of mine
Old Apr 6, 2007 | 06:12 PM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
No screws, they use double sided tape. I guess before you put them on you could make a small slit under where they were going, and inject some adhesive in there, but if you still have warranty, get them replaced...
And yes, they do eliminate the sore elbow problem.
John
To Is this a common problem?
