From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
Originally Posted by rkerr1234
Can the backs go to the front and you only need to buy two wheels, 2000 vert
Technically, the wheels will fit but if you have the OEM wheels, you currently have 17" on the front and 18" on the back. Not sure if you want to "rotate" them but if you do, it probably won't look good.
If you're talking about just putting the 18" on the front and buying a new set for the back, the offsets are different and your back 18's on the front will stick out about a 1/4 inch more...no big deal, it will look OK but just thought you should be aware of that
yes as per the above posts you can run 18's on all 4's just make sure the rear tires s are slightly larger or you could have active handling issues.
You can also go to 19 inch rears.
