Headlight Switch Question. Could use help!!
Old Apr 6, 2007 | 06:52 PM
MrBigButt98Conv's Avatar
MrBigButt98Conv
Default Headlight Switch Question. Could use help!!
Hello All !
I thought I was losing my mind. When I go to turn my running lights on in my 2002, my headlights pop up. Even with just the first spin of the switch. I know this is not supposed to happen. Any thoughts would be appreciated?
The famous actuator gear in one of my lights does need to be replaced, I get the grinding sound, but this can’t be the cause, can it?
Old Apr 6, 2007 | 06:54 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
I have seen grinding gears causing the problem you have described.
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Although I have not (yet) had the problem, it is not uncommon to hear both symptoms when the gear goes south...
Old Apr 6, 2007 | 07:08 PM
zTrek's Avatar
zTrek
More than likely, the problem you describe is due to a bad gear. Get brass replacement gears from Rodney Dickman. Excellent guy to do business with, great product!
To Headlight Switch Question. Could use help!!
