Low oil sensor location
Old Apr 6, 2007 | 08:37 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Default Low oil sensor location
OK I give up WTH is it?
Old Apr 6, 2007 | 08:45 PM
Benpup's Avatar
Benpup
sorry bout the double post, don't know what happened
Old Apr 6, 2007 | 08:47 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
X-plain what your question is.
Do you want to know where it is or what it is?
Is your Vette throwing a code?
Thanks,Matt
Old Apr 6, 2007 | 08:48 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Oil sensor location is under the intake manifold - if that was the question.
Old Apr 6, 2007 | 08:52 PM
BlackZ06's Avatar
BlackZ06
I think you're referring to the oil LEVEL sensor ... the one that turns on the LOW OIL message on the DIC. AC54ME is referring to the oil PRESSURE sensor.
It is located in the side of the oil pan, right rear side of engine. It is screwed into the side of the pan. If you have an automatic I believe you have to move (disconnect) the tranny oil cooler lines to get the sensor out. On a stick, should be able to disconnect wires and remove.
Old Apr 6, 2007 | 08:56 PM
Patches's Avatar
Patches
To Low oil sensor location
