Service Tire Pressure Sys???help
Old Apr 7, 2007 | 11:02 PM
o2z51's Avatar
o2z51
Default Service Tire Pressure Sys???help
wHAT ???? 1ST I CANT RESET THE TIRE PRESSURE SENSORS NOW IT SAYS SERVICE TIRE PRESSURE SYTEM??? SOMEONE HELP THE BATTERY WAS VERY WEAK IS THIS THE CAUSE?? THANKS
Old Apr 7, 2007 | 11:12 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
First - has the battery (car one) been changed?
If so, have you driven the Vette (remember it takes driving to reset the TMS - and NOT the RESET button)?
If both of the above are done and still have issues there may be a need (unusual) to 'relearn' the TPS - this is done by scrolling through the Options until you hit the blank screen - then holding the Option button until you see Learn Key Fob, then Learn tire moinitoring system.
Push on this and the horn will honk.
You will need a strong magnet - and starting at the left front using the magnet on the tire stem until the horn honks, then to the right front - same process, then the right rear - same process, then the left rear - same process.
Old Apr 7, 2007 | 11:48 PM
jrose7004's Avatar
jrose7004
The batteries may be dead and you may need to replace the sensors. www.gmpartshouse.com
Old Apr 8, 2007 | 10:22 AM
o2z51's Avatar
o2z51
i JUST PUT THE WHEELS ON LAST WEEK AND DIDNT RESET THE SENSORS, THEN WHEN I TRIED I COULDNT AND NOW THIS MESSAGE??
Old Apr 8, 2007 | 10:39 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
What year wheels? What year Vette?
Old Apr 8, 2007 | 10:41 AM
o2z51's Avatar
o2z51
tHE CAR IS A 02 THE WHEELS ARE CCW 505A'S WITH NEW SENSORS FROM WCC
Old Apr 8, 2007 | 02:22 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Did you retrain the sensors when you put the wheels (and new sensors) on the car?
To Service Tire Pressure Sys???help
