Need help with Leak!
Old Apr 8, 2007 | 02:48 AM
big gil's Avatar
big gil
Default Need help with Leak!
Hope i didn't mess up to much, lifted my car to change my brakes and while working on car i noticed coolant leaking from under car that i could not tell exactly from where it was coming from. Any help on clueing me into what type of problem i might have would be appreciated. Leak is dripping from brace holding spring. thanks, excuse confusing post, frist time trying to post pictures.
Old Apr 8, 2007 | 03:29 AM
VinceC5's Avatar
VinceC5
what year is your car? what color is the liquid? cannot tell from those pics. Not sure when they started using the long life orange coolant, but on my car it turned out to be one of my A/C lines.
Old Apr 8, 2007 | 10:08 AM
big gil's Avatar
big gil
My car is a 2002, and the leak is orange so i know its coolant, i just can't find where its coming from. I also had to add coolant one day when she started running hot and the heater started blowing cold air. Thanks.
Old Jul 3, 2007 | 10:26 AM
95BlueBomber's Avatar
95BlueBomber
Did you ever find this problem? I am having the same issue.
Old Jul 3, 2007 | 10:42 AM
Blown 346's Avatar
Blown 346
Have you checked the weep hole on the water pump? If it is leaking, while the car is running, the pulleys will throw it around and it will drip off of whatever it can.
Dye in the system will pin point the leak quickly. I would run the car let it get warm, sht it off and clean off the residue. Then look and you will find the leak.
To Need help with Leak!
