Is It Worth Changeing Intake???
Old Apr 9, 2007 | 07:58 PM
riarms's Avatar
riarms
Default Is It Worth Changeing Intake???
Im getting ready to change my oil pressure sensor in my 98 A-4 coupe. Ive decided that i will not cut a hole in my car to make this easy. Im going to take the intake off. Should I change to the LS-6 intake while I have the stock one off ? I have no mods on this car. I could put an aftermarket Blackwing or vararam but will not have money to do exhaust work for sometime.
Old Apr 9, 2007 | 08:03 PM
photoguy's Avatar
photoguy
Taking more air in is OK but you also have to allow it to escape. You will notice better performance with the cat backs along with the blackwing.
Old Apr 9, 2007 | 08:38 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
If you plan on doing other mods to the engine, like heads/cam/headers or supercharger, then I would change the intake to the LS6, but if you are just going to add an air intake, and cat-back exhaust, I would keep your stock one. IMO, you would get some gain, minimal and not worth the extra money.
To Is It Worth Changeing Intake???
