stripped bolts
Old Apr 10, 2007 | 02:18 PM
2004c5's Avatar
2004c5
Default stripped bolts
I have a coupe and the roof was starting to rattle a little when I hit bumps in the road so I tightened the 4 screws in the front of the panel. Unfortunatly I stripped one of the bolts really bad and I cant get the thing to turn in either direction anymore. Does anybody have any advise for me what I can do?
Old Apr 10, 2007 | 03:51 PM
Luv2Run's Avatar
Luv2Run
St. Jude Donor '13
By stripped I assume you mean the head of the screw is so damaged a screwdriver can't "get a bite" You can buy a special "drill bit" called a screw extractor that uses reverse threading. It will "drill" into the head of the screw and should turn it out so you can replace the screw with a new one. Not a hard job at all.
Don
Old Apr 10, 2007 | 04:01 PM
slayer6x6's Avatar
slayer6x6
An air hammer should do the job.
J/k, you should snap a pic of the damage we could see what were working with here.
To stripped bolts
