Help, overflow container leaking.
Old Apr 11, 2007 | 12:24 AM
rare-72's Avatar
rare-72
Default Help, overflow container leaking.
I just noticed my overflow container on my 99 is leaking. Upon closer inspection I found a tiny crack in the tube that the small rubber hose on top connects to. Can something like JB weld provide a temporary fix until I can replace the container. Which vendor offers a good price on this container? Anyone have a good used one available?
thanks for any help you can provide,
rare-72
Old Apr 11, 2007 | 12:55 AM
ALLEGRO's Avatar
ALLEGRO
rare-72
Before I purchased a new one I would pull it off, clean it (inside and out) and use some black or clear RTV to seal it off. Should be invisible as a repair and a heck of a lot cheaper than replacement.
Good Luck
Old Apr 11, 2007 | 11:28 AM
rare-72's Avatar
rare-72
Has anyone repaired their overflow container with RTV? Since it is pressurized I thought it might leak using RTV. Mine is cracked where the small hose attaches on the top. I am removing it today to clean it out and inspect the crack better.
Old Apr 11, 2007 | 04:38 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
I read in here somewhere that they aren't expensive at all and when mine gets to the point where I would remove it (very easy) I'd just buy a brand new one from Gene Culley and be done with it for another 9 years.
To Help, overflow container leaking.
