Rust stains
Old Apr 11, 2007 | 03:16 PM
slverc5's Avatar
slverc5
Default Rust stains
I've noticed some rust stains on the front speaker grills- color of the speaker grill is gray ( if anybody ask). I don't think the grilles themselves are rusted, looks more like a transfer than the grills themself getting rusted. -anybody here know how to remove the stains short of repainting them with flat gray paint.
I've tried a couple of stuff but so far hasn't work. I will be going to Wally Mart today and try CLR -if that doesn't work, I'll probably repaint it. But any suggestion before I do the repaint will be great. Thanks!
BTW - these are used pieces probably got the stains from long storage with other parts.
Old Apr 11, 2007 | 06:33 PM
slverc5's Avatar
slverc5
Guess nobody can suggest anything. Went to Wally mart and bought a product called Klean Strip, works very good but for those actual stubborn rust, had to do it twice. So mods please close this thread.Solved my own problem, sorry I asked first before actually trying more things!
Old Nov 7, 2007 | 05:06 PM
RTR's Avatar
RTR
i know this is an old thread, but i figured i'd post here instead of starting a new one. i've got this same issue. mine is actually the grills rusting some though. did you ever determine if yours was the grill rusting or just a stain? i'm wondering if it's worth the effort to try and clean them since it's in the little holes, or just look for some used/new ones in good shape...
Old Nov 7, 2007 | 08:33 PM
V-man's Avatar
V-man
St. Jude Donor '08
I've used 'naval jelly' before when I was restoring an old vert, worked pretty good. Hope this helps,
Old Nov 7, 2007 | 08:38 PM
Jet-Jock's Avatar
Jet-Jock
Yeow this is an old post.
I'm curious how did you get rust on the speaker grill? Is rusty water running down somewhere as from rain or something?
Old Nov 7, 2007 | 09:26 PM
slverc5's Avatar
slverc5
Mine were rust stain and a little bit of actual rust that went around the grille (front and back of the grille- not sure how it happened). Like I mentioned on my earlier post. Walmart sells a product called Klean Strip. I found it in the autoparts department where the bondo's, body repair, auto spray paint are located. It's not expensive ( I think it's about 5 maybe 6 dollars. Hope this helps!
Old Nov 7, 2007 | 09:28 PM
slverc5's Avatar
slverc5
I bought the interior door panel with the rusted speaker grille from ebay since I replaced my panel from black to gray- I'm thinking the rust stains/rust developed most likely in storage by the seller.
Old Nov 7, 2007 | 09:30 PM
ROJ#79's Avatar
ROJ#79
I have ther same problem and don't know how to address it!
Is it rust or stain??
I hate to rune the speaker working on it.
Old Nov 7, 2007 | 11:04 PM
RTR's Avatar
RTR
i'm not sure how mine happened, they were like that when i bought it. it's a convertible, so i guess it's possible the car has gotten wet before.
Old Nov 7, 2007 | 11:20 PM
Jet-Jock's Avatar
Jet-Jock
I'd think I would want find out why I'm getting rust stains.
Especially that there might be rust area going on in the A pillar perhaps. Not much else is metal.
Old Nov 8, 2007 | 01:23 AM
slverc5's Avatar
slverc5
You're not going to ruin the speakers, just remove the interior panel and then remove the grilles -the grilles have tabs that are bendable and that's how they are attached to the rest of the interior panel. I've removed the interior panels twice in the past just because I had a couple of projects, never had any problems!
Old Nov 8, 2007 | 08:35 AM
bucwheat's Avatar
bucwheat
Default Rust Stains
I had the rust stain problem,I think it's from sweat off your legs in summer when wearing shorts possibly,anyway I just pulled the covers ,took off the bose emblem and sanded then used rust killer primer ,painted them and have had no problem with rust coming back . Use good quality paint you won't be sorry.
Old Nov 8, 2007 | 09:25 PM
rob-cyn's Avatar
rob-cyn
I bet that they dont come with a good sealing coat of paint on them from the factory as I see it on C5s a lot so even humidity will cause oxidation.
Old Nov 9, 2007 | 02:32 AM
RTR's Avatar
RTR
yep, i thought possibly humidity also. it's like a jungle here sometimes in the summer. we can also get cooler nights after a warm, humid day where mist/fog/dew just hangs in the air.
To Rust stains
