Torque question?
Old Apr 11, 2007 | 11:11 PM
ransvett's Avatar
ransvett
Default Torque question?
Having new wheels put on my 02 z tommorrow when they put the lugs on do they need to be torqued to any certain spec??? Sorry if this is a dumb question
Old Apr 11, 2007 | 11:17 PM
2kbluevette's Avatar
2kbluevette
As far as I know the torque should be 100 lbs
nonsuchpro's Avatar
nonsuchpro
Old Apr 11, 2007 | 11:19 PM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
And re-torque after you drive a day or so
Old Apr 11, 2007 | 11:22 PM
Secret237's Avatar
Secret237
Torque valves are mostly dependant on the size of the bolt.
Since the size of the bolt, in this case, has not changed then yea, 100 ft. lbs. and tightened in the proper order, one bolt, then across from the first, never next to it and so on. I even take it in a few steps ... 60 lbs. first, then 85 .. etc.
If this is not done you could warp the rotors.
Old Apr 11, 2007 | 11:23 PM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
When I change my wheels out for drag racing and then back to stock I tighten in a star pattern and do two or three processes, 55 then 75 then 100 or 75 and then 100.
Like others suggest retorque after driving for a short while.
Old Apr 11, 2007 | 11:53 PM
oahuyahoo's Avatar
oahuyahoo
Supposedly to keep the rim from warping.
Old Apr 12, 2007 | 05:10 AM
RebelVette's Avatar
RebelVette
Here's a PDF of all the torque specs for the C5 (courtesy of Elite Engineering):
http://www.eliteengineeringusa.com/C5_Torque_Values.pdf
Old Apr 12, 2007 | 07:02 AM
I torque my lug nuts down to a final setting of 100 ft lbs.
Old Apr 12, 2007 | 08:12 AM
rws.1's Avatar
rws.1
100 ft-lbs on dry threads.
Old Apr 12, 2007 | 09:02 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
To Torque question?
