Guys check your wheels...........
Apr 13, 2007 | 12:14 PM
Just to let you guys know last yr while driving I felt like the car had a flat, I pulled over and found the wheel to be loose, turns out the upper control arm bolt fell out, I had it replaced and no problems until the other day, same thing now on the passenger side, just a word of caution check the rear wheels, my car only has 14k on the clock... The best way to give a quick check is to just pull on the wheel when parked, if there is some play in the wheel have it checked
Apr 13, 2007 | 12:19 PM
Good catch!
Apr 13, 2007 | 12:23 PM
Holy crap
Apr 13, 2007 | 12:31 PM
Damn glad you caught them in time
Apr 13, 2007 | 12:44 PM
my 04 had a re-call on something like that if i can remember,, its been 2 yrs ago,,however, gm fixed it and all is fine ,,, later rj
Apr 13, 2007 | 12:52 PM
Had a loose one myself last year. Felt like a bad shock when going over small bumps.
Apr 13, 2007 | 01:01 PM
I will check mine, thanks.
Apr 13, 2007 | 01:04 PM
Quote:
Originally Posted by
Tom/99
Apr 13, 2007 | 02:09 PM
Wow. I'm gonna check that out!!
Apr 13, 2007 | 02:25 PM
Hadn't heard that one. Thanks.
Apr 13, 2007 | 02:26 PM
WOW! Thanks for the heads up!
Apr 13, 2007 | 02:28 PM
I just shake my head at some of the things that go wrong with these cars. Thanks for the heads up!
Apr 13, 2007 | 02:35 PM
Chuck
Apr 13, 2007 | 04:42 PM
Happened to me on Saturday as I was coming into Houston from Dallas. My rear in started violently rocking the car as if my wheel was about to fly off. I couldn't go over 40 without it doing this. Crawled the car to a garage and found out it was the bolt that came out. Really scary symptoms for an easy fix.
Apr 13, 2007 | 05:42 PM
csexton
Chuck
That's scary!
Apr 13, 2007 | 05:50 PM
redjetty
What he/she said. Mine had the recall also, both sides were fixed, I believe, under warranty.
Apr 13, 2007 | 06:44 PM
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
Anyone have or can take photos of the bolt in question? I would rather check this myself before heading out on a road trip.
Apr 13, 2007 | 06:50 PM
o2z51
Only 14k? Your car is trying to tell you something....take it out of the garage once in a while!
I put 3000 on mine LAST WEEK...and even learned to ski (because there was snow on I-70 in Utah.)
Wish I could "not drive" my car...gas is getting expensive out here.
Cars and Coffee tomorrow!!! WooHoo!!!
Rad
Reason: Punctuation
Apr 13, 2007 | 06:52 PM
Be checking mine out as well. Thanks for the heads up
