Would it be better to......
Old Apr 14, 2007 | 09:57 PM
vetterlatethannever's Avatar
vetterlatethannever
Default Would it be better to......
I need to have my tranny rebuilt soon, I have the notchy feeling and I think the synchros are going. What would be the better way to go- Should I rebuild the tranny with the Z06 (M12) ratios or should I rebuild my regular MN6 and get gears? I was considering 3.90 or 4.10s but I really would like to keep the price reasonable so I can maybe splurge on some heads
Old Apr 16, 2007 | 12:18 PM
vetterlatethannever
TTT
Old Apr 16, 2007 | 12:20 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I would contact Rodney at RPM (supporting vendor) and discuss this with him. He will not steer you wrong.
Old Apr 16, 2007 | 12:57 PM
GoForBroke's Avatar
GoForBroke
It really depends on what you're looking for. The Z06 will give you roughly the equivalent of a 3.82 (in 1st gear) but you'll keep the final drive ratio in 6th giving you better mileage and less wear and tear at cruising speeds. The 3.90's/4.11's will give you more punch across the board, but at the cost of higher RPM all the time. If it were me, I'd go the Z06 route: get a good launch at the start (0-60 range) and still cruise at 1500 RPM on the freeway.
Good luck!
Old Apr 16, 2007 | 01:02 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Old Apr 16, 2007 | 01:03 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Apr 16, 2007 | 01:14 PM
electronbluec5's Avatar
electronbluec5
If you still like to drive your car around the street and drive long distances on the interstate I would go with the M12. I had a 2002 Coupe and the cruising ability was great. When I bought my Z06 I noticed better pick-up not only because of the increased HP but the gearing was much different. It still cruises nicely on the interstate but the gearing is a bit lower. At 80mph in my coupe I would be right at 1800rpm and now in my Z I run about 2100rpm at 80mph. With the coupe I would get about 28mpg at 80mph but now with the Z I have to drive 75mph to get that fuel economy.
Old Apr 16, 2007 | 11:50 PM
vetterlatethannever
Who? Actually I gave them a call to ask about a used MN12 and he priced me the rebuild for my MN6 and then to upgrade to the 12 which I thought was a very reasonable amount.
I do like the idea of keeping my cruising gears because I have a 25 mile trip one way to work. That said I guess I have my decision
Old Apr 17, 2007 | 01:05 AM
ptindall's Avatar
ptindall
Originally Posted by electronbluec5
I run about 2100rpm at 80mph. .
80 mph is 1900 in my Z. One of us has a tach or speedo miscalibrated.
Old Apr 17, 2007 | 01:30 AM
electronbluec5
I am pretty sure it's correct at 2100. I could be wrong but it's been that way since I have owned the car. If you get better than 26mpg at 80mph then yours is probably correct. It makes sense for there to be a significant efficiency drop from 1800rpm to 2100rpm but not from 1800 to 1900rpm. Let me know what you think.
Greg
Old Apr 17, 2007 | 01:07 PM
vetterlatethannever
Maybe some Z's had the 6th gear different also (just a thought), I was thinking it was .50 on a MN6 to .56 on an MN12. Shouldn't be a big difference in RPMs if the stock gearing is still in place.
I'll do some research on the right numbers.
Old Apr 17, 2007 | 01:11 PM
vetterlatethannever
LS1/MN6 LS6/M12
1st Gear 2.66:1 2.97:1
2nd Gear 1.78:1 2.07:1
3rd Gear 1.30:1 1.43:1
4th Gear 1.00:1 1.00:1
5th Gear 0.74:1 0.84:1
6th Gear 0.50:1 0.56:1
Reverse 2.90:1 3.28:1
Vehicle Speed @ Redline
LS1/MN6 LS6/M12
1st Gear 51 48
2nd Gear 76 69
3rd Gear 104 100
4th Gear 136 143
5th Gear 175 171
6th Gear N/A N/A
Reverse - -
Old Apr 17, 2007 | 01:26 PM
vetterlatethannever
If I am doing the math right, and its been a while so it may not be, 1,941 should be the RPMs turning when you are at 80 in a Z.
To Would it be better to......
