[Z06] Center console
Old Apr 15, 2007 | 02:36 PM
ca-dryheat's Avatar
ca-dryheat
Default Center console
Is the console only supposed to open about 1/3 of the way? I can barely open it far enought to push the gas tank button.
Old Apr 15, 2007 | 02:40 PM
DBL001's Avatar
DBL001
pull it towards u as u pull it up
Old Apr 15, 2007 | 04:10 PM
NorthTexasVette's Avatar
NorthTexasVette
I just figured that out yesterday..
Old Apr 15, 2007 | 04:49 PM
TEXHAWK0's Avatar
TEXHAWK0
It has a compound hinge... Open it straight up slowly at first, then put a drop of oil on each of the hinge points...
Old Apr 15, 2007 | 04:52 PM
rgtkst's Avatar
rgtkst
mine did this when the rear hinge of the compound part was broken. there is a little flat piece of metal conecting the hinged part. must be apart to see. easy to take it apart and see if its hanging up. new hinge costs around $40 or so. you must remove the entire rear section of console to get to the lower hinge blots.
Old Apr 15, 2007 | 07:20 PM
jclarksnakes's Avatar
jclarksnakes
Another good reason for me to read the posts on this forum.
Jeff
Old Apr 15, 2007 | 07:31 PM
z06Bigbird's Avatar
z06Bigbird
Cussing a little bit also helps.
Ed
Old Apr 15, 2007 | 08:32 PM
ca-dryheat's Avatar
ca-dryheat
Amazing.... Works like a champ now. A little lube and it works fine. Thanks guys!
Old Apr 15, 2007 | 09:50 PM
sapper1's Avatar
sapper1
BFH works as well
Old Apr 16, 2007 | 01:37 AM
striper's Avatar
striper
Also, it is easier to open if the brake handle is down.
Old Apr 16, 2007 | 06:59 AM
zulatr's Avatar
zulatr
use silcone spray, not oil, when lubing plastic. petroleum products will soften some plastics - they're both made out of dinosaurs...
Old Apr 16, 2007 | 09:52 AM
76REDVETTE's Avatar
76REDVETTE
Mine does the same thing! Gonna lube her up later
Old Apr 16, 2007 | 04:42 PM
Marcs c5's Avatar
Marcs c5
WD-40 works good
Old Apr 16, 2007 | 10:26 PM
TEXHAWK0's Avatar
TEXHAWK0
At least the hinge is not plastic.
I just used light machine oil with a pin-point applicator.
To Center console
