Those with piaa1100x
Old Apr 15, 2007 | 06:18 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Default Those with piaa1100x
How do they mount to the factory brackets?
Anyone have a picture?
Old Apr 15, 2007 | 06:27 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Ok, I found some good info here....http://www.corvettedreams.com/piaa-i.pdf
Old Apr 16, 2007 | 09:46 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
I just got my lamps over the weekend and that write up will come in handy. Thanks
Old Apr 16, 2007 | 11:04 AM
GB Vette's Avatar
GB Vette
CF Over the Hill Member
Cruise-In IV Veteran
CI-4 Car Show Winner
Cruise-In VI Veteran
CI-6 Car Show Winner
Cruise-In VII Veteran
CI-7 Car Show Winner
St. Jude Donor '03-'04-'05-'06-'07-08-'09
NCM Ambassador
Here's a couple of installed pics...
Old Apr 19, 2007 | 10:22 PM
phils C5 vette
No pictures, but there is a screw on each side of the Piaa's where the bracket screw to the light.
It wasnt hard. The wiring took longer.
Old Apr 19, 2007 | 11:53 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Yup,
I got 'er done earlier this week, easy than I expected. And quite the difference in light.......I havent adjusted them yet.
Before
After
Old Apr 20, 2007 | 12:10 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Awesome... I love mine. GBVette's install is for a TS front facia like mine.
Old Apr 20, 2007 | 12:23 AM
JETZ's Avatar
JETZ
With the oem brackets.
Old Apr 20, 2007 | 12:28 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
This is how I mounted mine..
Mine didnt really fit the way i wanted with that long springy screw thing still in there.
Old Apr 20, 2007 | 12:34 AM
KeithG's Avatar
KeithG
I really want to do this mod. Have any of you that have these had an issues with the heat they produce melting the plastic around the fog lights? I was told by another local Vette owner that it can be a problem.
Old Apr 20, 2007 | 02:34 AM
striper's Avatar
striper
Since I have a Z06 I didn't have factory brackets to use. You can get aftermarket brackets if you need them from www.litewarehouse.com. As far as heat is concerned, I have had no problems and I've had them installed for a while now. I run them on all the time. The PIAA's are actually brighter than the low beams.
Old Apr 20, 2007 | 05:51 AM
2k2c5mike's Avatar
2k2c5mike
Old Apr 20, 2007 | 09:59 AM
Jake the Snake's Avatar
Jake the Snake
Its a very easy install and a great improvement! Adjust ment is the hard part.
Old Apr 20, 2007 | 10:39 AM
JJ 86's Avatar
JJ 86
Does the bumper have to be removed to install these?
Old Apr 20, 2007 | 09:14 PM
phils C5 vette
I think the easier way would be remove the headlight assembly, but that's not easy.
Remove the plastic access panels under the nose is easy to do, but makes the installation process a little harder.
The problem is the front brake air damn is a PITA to work around. Limber and thin forearms would make things ALOT easier.
I did it so anyone can !!
Old Apr 20, 2007 | 10:00 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
The only thing I removed was the plastic headlight surrounding, held by 3 screws, I hid the relay and wiring under the coolant tank too.
Old Apr 20, 2007 | 11:08 PM
BanditDude's Avatar
BanditDude
I installed mine in tandem with the Vararam, so the wiring was much cleaner. However, the lights are easily installed through the headlamp surrounds.
To Those with piaa1100x
