drone from headers at cruse?
Old Apr 16, 2007 | 09:04 PM
hk940's Avatar
hk940
Default drone from headers at cruse?
i have had my C5 for a few months now and i am looking for info on headers. i am thinking of going with Dynatech Kit with headers,x-pipe and high flow cats. i have the Corsa Pace car cat backs and want to "finish" the exhaust. how many more HP can i expect? My only concern is making sure the Dynatech headers don't give me a drone or excessive noise at cruse speed which is about 70-80MPH at 1500-1700 RPM. the Corsas are quiet and that is nice for the long road trips i make.
thanks,
hk
Old Apr 16, 2007 | 10:01 PM
Paulg680's Avatar
Paulg680
CI 7-8-9 & 12 Veteran
Wounded Warrior Escort '11
I also have the full Dynamax Supermaxx longtube header system which includes high flow cats and an X-pipe. Although this set-up will make your car a lot louder, it doesn't necessarily cause the drone you're worried about. I think the biggest contributor to drone is your catback setup. I have the twin-tip Borla Stingers which are fairly loud to begin with. Adding headers took them over the top! The car sounds awesome under acceleration but exhibits a fair amount of resonance in certain RPM ranges during cruise. Some people are fine with it while others can't stand it. It's all a matter of personal preference.
Try to find another C5 with the setup you're planning on and listen to it in person. It's the only way to be sure...
Old Apr 16, 2007 | 10:10 PM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
I agree with Paul, the catback design will, for the most part, dictate drone. With the Corsas you'll be fine at highway speeds
Old Apr 16, 2007 | 10:26 PM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
I put borla stingers on my stock exhaust and was fine. Later I put on AR headers and high flow cats and drone at 1500 rpm is horrible. 1500 is 75 in my car. Have to drive 80 or 65 to get away from it. I am putting a 4.10 rear in it later so that will change the rpm range.
Old Apr 16, 2007 | 10:36 PM
vettes4fun's Avatar
vettes4fun
I have a 98 Pace Car with Kooks long tubes and Corsa pace car exhaust and at highway speeds it sounds great there is no drone at all.
Old Apr 16, 2007 | 11:09 PM
NSTG8R's Avatar
NSTG8R
TPIS headers and straight pipes .. no drone here.
Old Apr 17, 2007 | 02:16 AM
str8upchevy's Avatar
str8upchevy
From: 90% of all Fords are still on the road.....the other 10% actually made it home!
I just installed my new TSP LT headers, Highflow cats, X-Pipe, and yes.....a new Corsa Indy/Pace catback system, and at cruising speed (1500-2000) I experience VERY little to no internal drone!!
WOT is a "WHOLE DIFFERENT" monster though......
Old Apr 17, 2007 | 02:19 AM
Chuck01's Avatar
Chuck01
Default Headers
I have same setup with Dynatech and Corsa, my Car is an A4 and at 75+ there is alittle Drone, I also have 3.42 gears and at 75 I am about 2200 rpms. If you have 6 speed, you should be ok... until about 80-85mph. But at higher speeds you have a some drone.
Old Apr 17, 2007 | 06:48 AM
Probably the best advice you can get.
Old Apr 17, 2007 | 07:04 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
I switched from GHLs to Corsa Pace after my cam , have kooks long tubes. ZERO drone in 6th at any speed...
Old Apr 17, 2007 | 05:01 PM
Cole's Avatar
Cole
thanks,
hk
Its not simply the headers - its the exhaust system. You will hear some additional sound from the headers because they are steel and not cast iron. You can also introduce vibration harmonics that are dampened by the heavy stock, cast iron headers. You will also notice increased volume flow through the exhaust because of improved breathing on hard acceleration, but if the Corsa's are quite at cruising speed now, you should see little difference.
Headers are worth it.
Old Apr 17, 2007 | 11:14 PM
hk940's Avatar
hk940
don't tell me that man
that will make me buy them
Old Apr 18, 2007 | 03:14 PM
mikefd's Avatar
mikefd
I had B&B Bullets on my vert and the drone was not too bad...but of course thats subjective...to some it might be, but once I added American Racing headers, the drone between 1600-1800 has increased a whole lot. The first day that I had the car I thought I might have made a bad decision and might have to change catback to something else, but I have gotten used to it now. With the drone you can still have a decent coversation without yelling to your passenger. From what I have heard, the catback exhaust will determine how loud your drone will be. If the exhaust had a drone before hand, more than likely it will increase after the header install.
Mike
Old Apr 18, 2007 | 04:54 PM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
St. Jude Donor '03 thru '20
I have the same setup that you are looking at (except now with a cam).
Both before and after the cam there was no drone. At cruise it is virtually no different than before the headers. Do it you won't regret it at all.
Old Apr 18, 2007 | 05:18 PM
tellefan's Avatar
tellefan
I've got the Corsa Pace car cat backs. Just bought the Dynatech Supermaxx kit with cats. These even look SEXY! Had the headers ceramic coated, now I've just gotta find the time to install them. David
Old Apr 18, 2007 | 06:04 PM
jay'szo6's Avatar
jay'szo6
I've got American Racing Headers w/ a Catted X Pipe and Corsa Pace Car Mufflers. Absolutely no drone, and phenominal sound under acceleration. I gained about 20hp at the rear wheels when I added the headers with a tune. Money well spent!
Old Apr 18, 2007 | 06:52 PM
zguy's Avatar
zguy
I don't believe the headers contribute to drone but I am not 100% sure. I can tell you with my Kooks LT's and Z06 TI's I had no drone whatsoever in any gear or RPM.
Once I swapped my catback to GHL's I now have a slight drone in 6th gear around 1800 RPM or so when cruising along the highway. If I did not love the sound of them so much I would have changed them out already.
There is an easy fix for this problem... Drive faster or switch to a lower gear.
To drone from headers at cruse?
