spark plug changing time...anything i need to know?
Old Apr 17, 2007 | 04:47 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default spark plug changing time...anything i need to know?
is there anything i need to know that's unique to a C5 corvette about changing the plugs? Special tools needed?
thanks.
Old Apr 17, 2007 | 04:51 PM
Mach2's Avatar
Mach2
Swivel ended 5/8 spark plug socket, short 3" extension, 5"-6" extension, ratchet wrench. Careful pulling the spark plug wires off the spark plugs. Slow and easy, and from what I've heard # 7 (all the way back on the drivers side) is the only tough spark plug to get out and in. I haven't done mine yet, but will change plug wires when I change plugs.
Mick
Old Apr 17, 2007 | 04:53 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
PM forum member HiLandR. He has done it a couple times
Old Apr 17, 2007 | 05:00 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
yes, you need to know that knuckle skinning is gonna happen...
Old Apr 17, 2007 | 05:18 PM
PUREFUN's Avatar
PUREFUN
St. Jude Donor '07-'08
http://forums.corvetteforum.com/show...ng+spark+plugs
Old Apr 17, 2007 | 05:37 PM
c5chris's Avatar
c5chris
Start with the right tools, I learned the hard way. I still can see scars of my sparkplug job from last year on my arm.
It really does not need to be replaced often. GM recommends 100K miles and there is a reason for that.
But then again, it's a learning experience and good measure. I really cant believe those things last 100k miles.
Old Apr 17, 2007 | 05:38 PM
Blowtorch's Avatar
Blowtorch
thanks.
Be prepared to give blood and brush up on your 4 letter word vocabulary.
Actually, you can get 7 of them done in about 10 minutes. The closest one to the firewall on the drivers side (#7 I think) will take the rest of the day
I did it at 50K I don't plan to ever do it again with the 100K plugs I put in.
Old Apr 17, 2007 | 05:50 PM
5ltrEATER's Avatar
5ltrEATER
Here's a tip, wear some gloves...
I used the "racing" type gloves for my motorcycle. Helped alot of the knuckle scrapping, but did make it harder to fit your hand in hard-to-reach areas...
Another thing I done was crack one or two of the plugs as I was putting them in. Made the car idle/run horribly, I couldn't figure out what it was. Luckily, the forum pointed me in the right direction and I got everything squared away.
Just take your time and be patient about it! Yes, the four letter word is mandatory!
Old Apr 17, 2007 | 05:56 PM
BATM4N's Avatar
BATM4N
If you have big hands, you'd better have a good supply of body bags ...uuhhh I mean band aids
Old Apr 17, 2007 | 05:57 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
I did hear that its best to start with #7. That way everything is downhill from there.
I also heard that if you're anywhere near the 100K mark just go ahead and buy the new wires before you start. That way when one sticks (and you destroy it) you'll have the replacement right there with you.
Good luck, and come back and tell us howit went. We're always up for good entertainment.
Old Apr 17, 2007 | 06:57 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Apr 17, 2007 | 07:05 PM
rcs128's Avatar
rcs128
Originally Posted by jbondfl
IGood luck, and come back and tell us howit went. We're always up for good entertainment.
you sick-o...
Old Apr 17, 2007 | 07:14 PM
Pizzano's Avatar
Pizzano
Case of cerveza
And a hell of a Chiropractor
Old Apr 17, 2007 | 07:30 PM
ajderzie's Avatar
ajderzie
The wires easily break when you pull them off so I would just get another set of wires and change them as well. Otherwise you'll need a lift to the parts store. A side ratchet might do the trick for an easier time with the plugs. I did it the hard way (with the trip to the parts store as well).
Old Apr 17, 2007 | 09:40 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Purefun: thanks for the link.
Much blood was spilled in the battle of the dynamat many moons ago.
My hand are relativly slender, but i'll be sure to wear gloves...hands are important to a pianist.
I'm going to be swapping out the wires too. They wires on there look like stockers and there's 107K on the clock. I've decided on a set of the GM performance red wires since they the price is reasonable and people here say they are of high quality.
Thanks for the help guys, i'll be sure to return with horror stories but first i have to wait until the parts get here.
Old Apr 17, 2007 | 10:15 PM
pala's Avatar
pala
St. Jude Donor '07
band aids,,
gloves
wuss'es, just change dem, in my day u had no special tools. what are these things called swivel sockets. gloves, beer etc etc etc you just did it,, and u liked it,
lol ,,,
Old Apr 17, 2007 | 10:38 PM
Blowtorch's Avatar
Blowtorch
Here's what you want.......pretty good deal!
http://www.stealthperf.com/cgi-bin/s...NGKW-TR55.html
To spark plug changing time...anything i need to know?
Old Apr 17, 2007 | 11:22 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
good deal indeed.
What's the difference between the TR-55 and the TR 6?
also is there a difference between the red and black wires other than the color?
How do the MSD wires compare to the GM wires as far as longevity and conductivity?
Old Apr 18, 2007 | 12:07 AM
2 GRUMPY's Avatar
2 GRUMPY
Changed mine out last week @87,207 miles and they had about 30% life left in them !!!!!
Old Apr 18, 2007 | 01:11 AM
Frozenfire's Avatar
Frozenfire
Number 7 is the worst, so do it first and get it out of the way. Buy some anti-sieze paste and put a small amount on the threads of the new plugs. If you use decent wires such as the Taylor, you can discard the metal EMI shields. Also make sure that the engine is cold before you remove the old plugs.
