Belt squeek
Old Apr 18, 2007 | 02:06 PM
Ishams00vette's Avatar
Ishams00vette
Default Belt squeek
I have had a LOUDDD squeek for some time now. I thought just replace the belt, BUTTT every one is telling me it could be the harmonic balancer. Have yall seen alot of these?? Looks like its almost shakes!!
Old Apr 18, 2007 | 02:08 PM
04cad's Avatar
04cad
St. Jude Donor '07-'08
Default Harmonic balancer
If the harmonic balancer is wobbling, you need to get it checked out asap.
Old Apr 18, 2007 | 02:22 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
it is usually the belts and/or the idler pulleys...
Old Apr 18, 2007 | 02:26 PM
mud flap's Avatar
mud flap
Im going out on a limb here and everyone is probably going to think Im nuts but back in the day when the belt in my little Corolla used to squeek I'd get a bar of soap and rub it on the inside of the belt. Then I'd start the car turn it off and repeat the process.
Hope this helps
Dave
Old Apr 18, 2007 | 02:42 PM
Ishams00vette
belts dont look TOOOO bad... They actually seem to be in good shape...... butttt... they are squeeling their buttttttt off...
Old Apr 18, 2007 | 03:34 PM
Jboger2K's Avatar
Jboger2K
Quest. 1....Does it sqeak, all the time, or start getting noisy after a warm up.
Quest. 2....Does it go away after about 1 hour of driving, or whatever,?
It is probably a pulley. I changed several before I found it.
Old Apr 18, 2007 | 06:13 PM
riarms's Avatar
riarms
I just changed the two belts in my car and all is well. used the goodyead gator ones
Good luck
Old Apr 18, 2007 | 06:23 PM
DjCritterus's Avatar
DjCritterus
St. Jude Donor '09
Check the pulleys on the A/C belt. Both of mine went bad and local parts stores don't carry them. They are a beotch to replace, too. Check some of the vendors on this site to get some quality ones much cheaper than the stealerships will sell them for.
Old Apr 18, 2007 | 06:58 PM
JPM@AutoBuffs's Avatar
0JPM@AutoBuffs
Former Vendor
From: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
S. Jersey Events Coordinator
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
Have them check the idler pulley...that was my problem
Old Apr 18, 2007 | 07:04 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
GM has a new belt idler pulley and tensioner to fix this problem. If anyone is interested please contact me directly.
Old Apr 18, 2007 | 08:08 PM
jpc0011's Avatar
jpc0011
Spray some water on belt. If squeal stops thats probably your problem.
Old Apr 18, 2007 | 08:17 PM
Blue Lion's Avatar
Blue Lion
I wouldn't wait to get this checked, or take a long trip...
My serpentine belt broke in December. I had the dealer replace it.
The belt soon started squeaking, which it hadn't done before. 300 miles later the new belt slipped off the pulleys. Stranded again.
This time they replaced the tensioning pulley. Your belt is telling you something is wrong.
To Belt squeek
