how to start engine?
Apr 18, 2007 | 11:33 PM
Quote:
Originally Posted by
Funn One
I wait for my gauges to cycle!
me too
Apr 18, 2007 | 11:49 PM
mmaynard
Insert key, adjust power seat, push in clutch, start,crank stereo, ...........smile.
We heard you the first time....
Apr 18, 2007 | 11:57 PM
I just get in push the clutch in, turn the key to on and while the guages are sweeping I put on my seatbelt, and by the time I have my seatbelt on the guages are done, then I start the car up.
Apr 19, 2007 | 12:03 AM
don't forget to check the before flight tags...so you don't end up in the flying roof club.
Apr 19, 2007 | 01:43 AM
I wait for my gages to cycle.
Ask me why, and I couldn't tell ya, but I do it anyway!
Apr 19, 2007 | 06:49 AM
Funn One
That's what I do.
Apr 19, 2007 | 09:52 AM
St. Jude Donor '07
Yep, let my seat memory cycle, gauges sweep, fuel pump cycle, then hit it. I also don't let it idle more than a minute before taking off. Unless it's below 20 degrees, I'll wait a couple if minutes. I just drive slowly for five miles till warm.
John
Apr 19, 2007 | 12:07 PM
I turn the key and let the guages cycle, start the car and wait to put it in gear until the oil pressure gets up.
Apr 19, 2007 | 01:47 PM
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
turn key to on, yell 'clear' out the window and fire her up...
Apr 19, 2007 | 02:20 PM
St. Jude Donor '20
jrose7004
Apr 19, 2007 | 03:03 PM
St. Jude Donor '06 thru '15, '19
Apr 19, 2007 | 03:04 PM
Here's the deal....
Sparky22
what sound does the fuel pump make when its turning on?
Stick the key in. Seats get adjusted. AC/radio turn on right away; I shut them. The gauges cycle very quickly, so I don't pay attention to that. BUT I let the fuel pump do its thing, and get it going, and THEN I CRANK. This way it cranks sooner. Otherwise, it takes another second of cranking, which I'd rather avoid (during cold starts). After this, let it warm up for a mintue or so, or push on the gas a lil to get it goin'''
Apr 19, 2007 | 03:25 PM
Vette Dream
Chevy Mechanic told me that you should always do this...and that if
you don't wait for the gauges to cycle you may wind up with
EBCM issues/malfunction..
Not sure about that...never saw the connection..
Apr 19, 2007 | 06:10 PM
St. Jude Donor '08
jasons0147
I use my remote
you have a remote start?
Apr 19, 2007 | 06:21 PM
Funn One
Apr 19, 2007 | 07:00 PM
This is all very interesting, but is there anyone lurking about here that knows what the "proper" procedure. Perhaps a GM engineer?
Apr 19, 2007 | 10:14 PM
I like to let the guages and lights cycle so I can review them. It also lets the fuel system pressurize.
Apr 19, 2007 | 11:26 PM
FAAASTJEDI2000
I like to let the guages and lights cycle so I can review them. It also lets the fuel system pressurize .
That's exactly what the guy in post #32 said. But this is the right way in a nutshell.
