New tires, need alignment?
Old Apr 18, 2007 | 10:45 PM
Illini82's Avatar
Illini82
St. Jude Donor '07
Default New tires, need alignment?
I'm planning on putting new tires on my car, hopefully next week. Do I need to get an alignment? I'm putting stock size GSD3's on. In the past I've always done it, but I was just curious what others are doing.
Do you get an allignment when you lower your C5's too? I was planning on maybe doing this in a few months too, so will I need to do it again?
Sorry, my complication is that I was planning on going to an autox on the 28th and there's no way my bald run-craps will get me in, but I also don't want to risk uneven wear but pushing them for a few days.
Thanks for the help guys!
Old Apr 18, 2007 | 11:02 PM
R Devil's Avatar
R Devil
IMO new tires or lowering = alignment check. Money well spent.
Old Apr 18, 2007 | 11:07 PM
ICaughtVetteFever's Avatar
ICaughtVetteFever
Wait till you lower than allign to Z06 specs, you don't need the runflat allignment anymore.
Old Apr 18, 2007 | 11:10 PM
02MillenniumVette's Avatar
02MillenniumVette
You dont need an alignment when you change your tires but you will when you lower it. I suggest you just get the C5 alignment not the Z06 alignment, unless you plan on autocrossing your car.
Old Apr 18, 2007 | 11:47 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
I think a good alignment is good $ spent. Why spend maybe $1200 on tires and not $88 on an alignment? Just have the shop drop it on stock bolts before they set the alignment specs probably at the same time the tires are mounted.
Old Apr 19, 2007 | 06:39 AM
Good time to get both things done.
To New tires, need alignment?
