paint code question
Old Apr 19, 2007 | 09:09 AM
camarossrulz's Avatar
camarossrulz
Default paint code question
where is the paint code on a 2000 c5?
Old Apr 19, 2007 | 09:17 AM
11yellowgscpe's Avatar
11yellowgscpe
Check the label in the glove box that has the RPO's for parts listed.
Old Apr 19, 2007 | 09:18 AM
02MillenniumVette's Avatar
02MillenniumVette
I believe its either in the glove box or on the drivers side door.
Old Apr 19, 2007 | 09:24 AM
RedY2K's Avatar
RedY2K
Does this help?
10U Arctic White
11U Light Pewter Metallic
13U Sebring Silver Metallic
23U Nassau Blue Metallic
28U Navy Blue Metallic
41U Black
70U Torch Red
79U Millennium Yellow Clear Coat
86U Magnetic Red-II Clear Coat
91U Dark Bowling Green Metallic
Old Apr 19, 2007 | 09:38 AM
Old Apr 19, 2007 | 09:48 AM
steve8's Avatar
steve8
Originally Posted by GaryP
Does this help?
10U Arctic White
41U Black
70U Torch Red
That should do it.
Old Apr 19, 2007 | 11:05 AM
z06Bigbird's Avatar
z06Bigbird
Does this help?
10U Arctic White
41U Black
70U Torch Red
You can always get a big screwdriver, scrape a piece off of the hood or someplace and take it to these new digital paint shops. They can match it perfectly.
So far, I have done this with white paint, and I use toothpaste to cover up the scratch. Comes fairly close. Maybe crayola crayons for the others???
LOL
Ed
Old Apr 19, 2007 | 12:14 PM
GrayC5's Avatar
GrayC5
Does this help?
10U Arctic White
41U Black
70U Torch Red
The above are RPO codes, not paint codes. The "WA" (factory) paint code can be found toward the bottom of the car's Service Parts Identification (RPO) Label. For model year 2000, the Service Parts Identification Label should be on the inside of the car's glove box lid. In the example pic below, U 382E is the "WA" paint code for this model year 2000 car which is painted Light Pewter Metallic. Your car's "WA" paint code should appear in the same place on its RPO label. The following link also shows the "WA" and other paint codes for the 2000 model year C5 (see "Paint Codes" toward the bottom of the link):
2000 Corvette Specifications
HTH
Service Parts Identification Label:
Old Apr 19, 2007 | 03:31 PM
MYRagtop's Avatar
MYRagtop
Try this
http://www.corvettepaintcodes.com/
To paint code question
