[Z06] 7000rpms?
Old Apr 20, 2007 | 03:22 AM
rkaslyfox's Avatar
rkaslyfox
Cruising
Default 7000rpms?
I need some advise. . . .I'm wondering how safe it would be for me to take my rpms to 7000. I have a custom cam 240/244 duration, 612 intake and exhaust lift, with 112 lsa, .650" dual gold spring,titanium retainer,machined steel locks, hardened spring seats and gm seals. My peak hp occurs at 6000rpms and peak torque at 5200rpms. However, I noticed on the dyno graph that the hp isn't dying off after 6500rpms, is it worth it carry on to 7000rpms?
The rest of the mods are in the sig.
Old Apr 20, 2007 | 06:44 AM
MVR 155's Avatar
MVR 155
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
If your still making steady HP after 6500 and your not dropping off hard on the torque then spinning it a bit more wont hurt you one bit, I dont know if you need to go all the way to 7K but unless you get it on the dyno all the way to that number you wont know for sure, I would say bump your limiter to 6800-6900 and shift it a couple hundred RPM higher
Old Apr 20, 2007 | 06:50 AM
Zosickness's Avatar
Zosickness
I have similar stuff on my car and i have my limiter set at 7200 rpm's.
To 7000rpms?
