[Z06] Stock replacement rotors???
Old Apr 20, 2007 | 10:30 AM
droid's Avatar
droid
Default Stock replacement rotors???
What is the best choice. I only have 17,000 on my original stockers. I have turned them twice now because of warping and they are once again warped and no more stock to turn. What is the best replacement? Another set of stock ones or are there aftermarket slotted and drilled? Does anyone else have a issue with warping?
DROID
Old Apr 20, 2007 | 11:04 AM
99vettecoupe's Avatar
99vettecoupe
DROID
The Brembo stock replacement rotors are great. Inexpensive and I have had no warping after HPDE's.
Old Apr 20, 2007 | 11:32 AM
droid's Avatar
droid
Wheres the best place to get these? How much are they? Are they better than the NAPA replacements that everyone seems to use for $25 a piece?
Andy
Old Apr 20, 2007 | 01:36 PM
99vettecoupe
Andy
You can get them from TireRack. They are more expensive than the NAPA replacements ($77 ea. front, $44 ea. rear). I have not tried the NAPA rotors since the Brembo's work for my driving style and I would rather not find out the hard way.
Old Apr 20, 2007 | 01:42 PM
UstaB-GS549's Avatar
UstaB-GS549
It's pad material build-up rather than rotor warpage that gives pulsation in pedal. Turning rotors is old school and makes the situation worse by thinning the rotor.
Go to Stoptech website for a very good explanation by Carrol Smith about the Myth of brake rotor warpage.
I would replace the pads with a different brand than what you are using now. The pads are the problem.
As far as rotors go, you can get the cheap ones from NAPA or RockAuto.com for about $25 each. They are all the same and work fine for everything from street driving to racing. If you want bling, sky is the limit on what you can pay for rotors. Drilled, slotted, etc. don't perform any better than the plain flat ones, but if you like the looks, go for it.
Old Apr 20, 2007 | 01:49 PM
UstaB-GS549
Andy
I have been told that Brembo's are the same Made in Canada rotors in a different box with a higher price. I have purchased the Raybestos Pro-something, Raybestos Red-something (really cheap) and AC Delco rotors from RockAuto, NAPA and know that they are all the same rotor.
The OEM GM rotors cost more and are not the same as the rest. They are made in Brazil, are dynamic balanced & blanchard ground. The "cheap" rotors have seen speeds up to 145 and braking down to 45 for turn 5 ar Road America and don't seem to suffer from surface finish or balance problems.
Old Apr 20, 2007 | 02:01 PM
jbauch357's Avatar
jbauch357
+1 on the more likely problem of pad buildup rather than actual warpage.
get the car up to ~80mph and dynomite the breaks down to about 20mph, get back up to speed then dynomite again, do it one more time than drive the car normal to give the brakes a chance to cool. this should remove the majority of pad buildup.
to keep from getting that buildup:
- learn to brake harder and for a shorter amount of time to keep the brake temps down and the buildup to a minimum
- get better pads that will be less likely to heat up, i.e. more aggressive or just generally higher quality
NAPA rotors and Hawk HP Plus pads seem to be perfect for my driving - but may be a bit aggressive for your driving habits...
Old Apr 20, 2007 | 04:08 PM
Last C5's Avatar
Last C5
Somebody go out and buy a set of these new ATE rotors that Tire Rack is selling for $38 apiece and try them out. I want to know how well they work. ATE is a good company and makes a top notch brake fluid, hopefully these new rotors are as good.
Old Apr 22, 2007 | 08:32 AM
Camaroguy22's Avatar
Camaroguy22
What is the added distance in stopping using GM Ceramic Pads vs. Hawk HP Plus Pads?
Old Apr 22, 2007 | 08:45 AM
spdislife's Avatar
spdislife
should be zero...that number has more to do with tire adhesion and the weight of the mass you're stopping
Old Apr 22, 2007 | 09:03 AM
lbarnard's Avatar
lbarnard
If you like the look and feel of drilled rotors Italia makes a great set. Or if you want to keep stock either NAPA or RockAuto sells a set for $122.00 all 4 including shipping. I run the RockAuto PG at race events. Made in Canada.
Old Apr 22, 2007 | 11:25 AM
Ranger's Avatar
Ranger
It's been 20+ years and six Vettes ago since I had a rotor warp.
Why is that?
Because I learned the requirement to hand torque the lug nuts
(1) on delivery and then again
(2) anytime a wheel is remounted.
Most "warped rotor" are actually the result of improperly torqued lug nuts. Victim of wheel technicians with an air gun that "absolutely torques them dead-nuts everytime." Yeah right.
So that's the place to start. Retorque the lug nuts.
If that doesn't solve the problem then ridding build-up on the pads is the next step.
Ranger
Old Apr 22, 2007 | 11:28 AM
Ms Eliz's Avatar
Ms Eliz
There are only a few brake rotor foundries in existence (Steel Plants dedicated to rotors, drums, wheel cyl., steel calipers).
I used to work for Wagner Brake as a rep a few years back. We manufactured and machined rotors from casts in CNC cells at our St. Louis foundry (ONLY US FOUNDRY, at the time). These same rotors where sold to other large brake companies to box under their lables as well as marketing them under our brand. AND...even though we owned our own foundry, we did not make every rotor or drum we sold. We purchased low volume stuff from other sources, cheap off-shore people occassionally, but normally the O.E. manufacturer. Wagner is/was the largest supplier of aftermarket brakes in the world...but they did not even make their own friction material for ANY APPLICATION until the mid 90's when they purchased a canadian friction company.
Too many years have past for me to tell you who owns what friction (pad) manufacturer, foundry etc. But I can tell you for a fact you can pay doble or triple for the same product in a different box at different levels of distribution under different lables.
Research is the key to finding a prime manufacturer of any part.
If you want GREAT aftermarket pads for a daily driver...buy Raybestos.
Old Apr 22, 2007 | 08:54 PM
vms4evr's Avatar
vms4evr
That is exactly the point that a lot of people don't understand. The $26 NAPA rotors we all call the "cheap rotors" are made in Canada. There is only 1 foundry there. Those same rotors get boxed and sold under Raybestos and other name brands. Same rotor, different packaging. So go ahead and buy then under the Raybestos name and pay 3x the price for a pretty box. Just stay away from the Made in China rotors. They are complete junk. They'll warp, crack, shudder, etc.
The GM rotors that came on my Z06 were made in Brazil as UstaB-GS549 noted. They're pretty good quality. But why mail order rotors and pay shipping on a heavy part. Mine cracked on the track just like the NAPA ones do. Now if I was only street driving my car I would probably go for the bling with drilled/slotted rotors cause they look cool. Worthless on the track though... Slotted maybe ok depend on who cut them.
Old Apr 24, 2007 | 01:34 AM
skeet's Avatar
skeet
I can not wait for mine to warp so I can get rotors with aluminum hats. I would imagine you can feel the weight difference?
To Stock replacement rotors???
