Dimming headlights....
Old Apr 20, 2007 | 09:18 PM
bilx013's Avatar
bilx013
St. Jude Donor '12
Default Dimming headlights....
Anyone experiancing dimming headlights while driving? I get a flicker once in a while and can't figure out why? New battery was installed last summer. Please chime in....
Old Apr 20, 2007 | 09:23 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I've seen this same thing in my '99 for the entiire life of the car. I believe it happens when the alternator switches from high rate charge to a lower rate charge or when the rpm falls off enough during the high rate charge mode. Having said all that, I think its the built in regulator, but there has never been a problem on mine with that system.
Old Apr 20, 2007 | 09:31 PM
Blue Lion's Avatar
Blue Lion
The only times I've had this problem are when I push the power window buttons (drain on system; perfectly normal from what I hear) or when my serpentine belt went out. I assume this isn't happening to you.
Old Apr 20, 2007 | 11:15 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
the "big 3" mod can help solve this problem:
It involves running three 4 awg wires:
a) from alternator mounting bolt to frame
b) from alternator positive to battery positive
c) from battery negative to frame
Your stock alternator (depending on it's model) has a output capacity of 110 or 140 amps. Your stock charging cable is thick stranded 8 awg and has a carrying capacity of less than 100 amps.
Running the 4 awg wire IN ADDITION to the stock wires reduces the resistance on your alternator significantly allowing it to work more effectively.
here's my setup:
without alternator:
wires through battery compartment wall:
Grounding points on the frame are up to the user. The hood frame mounts are wat i'm currently using. i reccomend purchasing special grounding feet for the wires for maximum current transfer.
See the audio section for more information.
Old Apr 21, 2007 | 12:07 AM
Oldvetter's Avatar
Oldvetter
Check your battery terminals, make sure they are tight. If you can move them by hand, they are too loose.
Be careful, over tightening battery bolts can cause it to leak, only use 11 ft-lbs torque.
Old Apr 21, 2007 | 09:45 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
overtightening can also cause them to fall off.... (don't ask me how i know this..... )
Old Apr 21, 2007 | 10:13 AM
Jims99frc's Avatar
Jims99frc
Mine has done the same thing since I have owned it . It seems to "dip " in voltage for just a split second . It goes away when the car is all warmed up .
Not yet a problem , just strange .
Old Apr 21, 2007 | 10:14 AM
happa's Avatar
happa
Thanks Man! Ive been doing that for a long time, time to go fix it!
Old Apr 21, 2007 | 10:51 AM
bilx013's Avatar
bilx013
St. Jude Donor '12
I'm glad to hear I am not the only one with this problem. It has been happening since I bought the car also(1 1/2 years ago) I will check the terminals to make sure they are tight, but not to tight. I will also look into doing "The big three". Thanks again for all your input
Old Apr 21, 2007 | 10:55 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
When I had OEM lights, mine did it, even on other cars. I thought it was "normal".
The big 3 idea is awesome from what I've read. I never got around to it.
Old Sep 16, 2007 | 09:46 AM
minitech's Avatar
minitech
I also ran an extra ground to my alternator along the way to finding out I had a loose positive termainl. Question is: Isn't the alternator already grounded being massively bolted to the engine which is bolted to the frame? Or is the engine not grounded? Thanks.
Old Sep 16, 2007 | 01:08 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
If i rember correctly the engine is slightly grounded but the resistance through all the bolts, mounts and crap all adds up. The only reason to run 2 ground wires is because most of the electrical components use the chassis as a ground.
Old Sep 16, 2007 | 03:26 PM
TNX ZORA's Avatar
TNX ZORA
If I missed this, sorry, but could you give some details on that blue wire you used for your "Big 3" mod"? I suspect it has a copper conductor(?) but the blue insulation is what I'm especially curious about - how it holds up under engine heat and so forth.
To Dimming headlights....
