Z06 Grill question
Old Apr 20, 2007 | 10:45 PM
mickey_7106's Avatar
mickey_7106
Default Z06 Grill question
so i bought the vararam kit for my car but i dont want to install it untill i get the z06 screens. i ve search the forum for screens and the cheapest ones i could find were from wcc @$99. so my question is how do install them. ive read that ppl use the "velcro method". what other method is out there. any info will be appreciated
Old Apr 20, 2007 | 10:57 PM
Ralphyboy's Avatar
Ralphyboy
St. Jude Donor '08-'09
I'm waiting for mine from Mid America. The guy on the phone who took the order said that they have double sided tape to attach them. He said to be careful because it's kind of a one shot deal to get them right. We'll see. I should have them in a day or so.
Old Apr 20, 2007 | 11:07 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
you can also use silicone which gives you the ability to move it around if you don't get the perfect fir the first time. The cool thing about silicone is that excess comes off clean with no residue. I used black silcone from Home depot to install my front grilles.
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
I don't know how the stock ones are fixed but mine (Vetteshoppe) use velcro. The go in very well and aren't coming out without a fight.
I placed mine in the openings and pushed them tight making a note of where the velcro layed. I then taped the other side of the velcro about a 1/4" back in further. Then I layed a piece of thin cardboard on the velcro and put the grills in and pushed them in hard so the velcro lined up right. Pull the cardboard out and voila!
Ralphyboy - I can't imagine how you're gonna get them all the way in using double sided tape. That tape is gonna stick WAY before you get them all the way back.
Old Apr 20, 2007 | 11:23 PM
mickey_7106
wow! sounds like a PITA
Old Apr 20, 2007 | 11:42 PM
Mach2's Avatar
Mach2
Ralphyboy, try some wax paper over the double sided tape maybe, or fold back a corner of the tape paper backing and get them in position, then pull the rest of the paper backing off after they're in position.
Might also suggest just removing the double sided tape from the screens, then apply velcro. I bought some 3/4" velcro in squares from a craft store. Then apply the screens with the velcro like jbondfl says. I used the 3/4" velcro squares to install mine from GMPartsHouse.com.
Mick
Old Apr 21, 2007 | 12:49 AM
jmzvet's Avatar
jmzvet
I Velcroed mine but anything will work. There is no reason to remove them for cleaning, maintenance, etc.
Old Apr 21, 2007 | 11:21 PM
mickey_7106
Does anybody know how they're installed in a Z06?
Old Apr 21, 2007 | 11:32 PM
unionlandlord's Avatar
unionlandlord
C5 General
From: Boosted in Manhattan & Round Rock TX. President of the Non Club Club of Kansas and Round Rock , Not the flat part.
If you have it taken apart thare are 2-3 screws that hold them in.
I have OEMs and used Velcroe Its easy and holds grate.
Paul G
Old Apr 23, 2007 | 08:48 PM
Ralphyboy's Avatar
Ralphyboy
I got them Saturday morning, and had to get them in before the Northeast T shirt cruise Sunday .They went in with the double sided tape OK( you have to lift the top of them up and then let the bottom touch because the tape is only on one side, and on the bottom of the piece), but I'm not sure that I like the position of them. I looked at some ZO6's Sunday, and it seems that mine aren't in as far as theirs are.I dry fit them before I used the tape, and thought it was right. I may try the velcro method since I have some from some other projects. Thanks for the suggestion guys.
Old Apr 23, 2007 | 08:54 PM
gotvet's Avatar
gotvet
Use velcro, you will eventually want to take them off to clean in there.
Old Apr 23, 2007 | 08:58 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Everything good is worth some effort.
Old Apr 23, 2007 | 09:36 PM
Blue Lion's Avatar
Blue Lion
Got mine from MidAmerica. They are in with the provided tape and it's secure. It's not hard.
Old Apr 23, 2007 | 10:42 PM
You can do the velcro method, the double sided tape method or screw them in like on the Z06. My advice, go with the velcro.
Old Apr 23, 2007 | 10:47 PM
redazz's Avatar
redazz
they use clips 4 per side i had mine for two years very solid
john
Old Apr 24, 2007 | 11:28 AM
mickey_7106
cool! thanx a lot dudes!
Old Apr 24, 2007 | 04:00 PM
Zenak's Avatar
Zenak
Terminal Vette Addict
Default Just did it this weekend.
Just did mine. I pulled out the factory fog light shroud to increas the air flow. It was a bitch to get in there to unbolt and get those suckers out. Wound up jacking up the car, tkaing off the air fliter and the front radiator shroud and then going in from the bottom.
Used the double sided tape that came with them, but also drilled in 2 holes for each one (bottom side) and then used 2 body clips and screws per side which is what the factory Z06 mount looks like.
Cleaning? Just spray the garden hose :-P
Be careful taking out the old fog light housing because there is a wire grommeted in to it that you will have to relocate to the new screen housing.
Z.
To Z06 Grill question
