Just got a 50th AE with very, very low miles and I am getting a "left front low tire pressure" message. It goes away after 15 minutes or more of driving. should i have it checked out? (got gm 3/36) my 02 never had this problem.
Your tire pressure is low and heat from driving makes your tire pressure go up a few pounds. 30 cold
2 possibilities... As stated above if the cold temperature pressure is 25 or lower you will get the message. as the tire heats up the temperature rises and the message goes away.
Check your tire pressure.....
1. Your tire pressure is below 25 psi.... i.e. you have a slow leak... may be a nail puncture...
2. Your tire pressure is not below 25, you do not have a slow leak, but the battery in the sensor is dying....
UHHH, I hate to point out the obvious, but push reset to get rid of the message and then cycle through the gages section of your DIC to see what your pressure on the LF tire is reading. As mentioned, it is probably below 25, and needs servicing.
From: "Man been singin' the Blues, since he began to till the ground"...Vancouver, USA WA.
One more option for a leak that I experienced, I put the valve stem cap on to tight, and the rubber "O" ring wadded up inside the cap and was pushing on the valve stem core.
