I'm going to be installing my HID kit and noticed there was no mounting bracket for the ballast. I was thinking about making a bracket myself but wanted to see if anyone had experience with this (or possibly a quick/easy solution).
Have any of you installed it without a mounting bracket?
I mounted my ballasts on the frame. I put one on each side up front, I put the ballasts on with the sticky tape provided, drilled 3 holes, and screwed them in.
Mine are mounted to the headlight support bracket underneath the headlights. I used a dremel tool and removed the lip from the bottom of the left side the bracket to mount the ballast, the right bolted on with no problems.
I mounted them under the headlights because I wanted them hidden and out of the weather.
