[Z06] Please Help!
Old Apr 21, 2007 | 09:06 PM
BLACK Z06 VETTE's Avatar
BLACK Z06 VETTE
7th Gear
Default Please Help!
I installed the callaway honker yesterday and it is awesome. It is a great system and I can feel a difference in the performance. BUT, as I tried to unroll the windows to listen to the intake on a test drive, the passenger window did not go down. I never had a problem before. Did I mess something up? Or is this a coincidence. Please Help.
Old Apr 21, 2007 | 09:44 PM
Ranger's Avatar
Ranger
Originally Posted by BLACK Z06 VETTE
...As I tried to unroll the windows to listen to the intake on a test drive, the passenger window did not go down. I never had a problem before. Did I mess something up? Or is this a coincidence. Please Help.
Coincidence. Probably a failure of that window switch. Common issue. Only one I remember having on my 02Z. It also leaves a code. For convenience, here are the four codes covering both window switches.
B2206 Right Window Up Switch Fault
B2208 Right Window Down Switch Fault
B2202 Left Window Up Switch Fault
B2204 Left Window Down Switch Fault
Suggest pulling the codes and check for those. Procedure is in the FAQ sticky.
Let us know what you find.
Ranger
Edit: Procedure for checking codes and the code equation list.
