ACA HID problem
Old Apr 22, 2007 | 12:30 PM
1KLRTOY's Avatar
1KLRTOY
Default ACA HID problem
I have the ACA HID's installed and one quit working , they have been in for 6 mos and would like to know how to tell if the problem is with the bulb or the ballast, I've checked the fuses and their ok. The replacements are pricey ($150ea.) so its hard to guess by just buying what you think is the obvious (the bulb) also any recomendations as where to buy parts if nessicary?
Old Apr 22, 2007 | 01:21 PM
KalelC5's Avatar
KalelC5
sounds like the problem is most likely the relay. The same thing happened to my HID's, one stopped working, I thought it was the ballast, and turned out to be a bad relay...good luck!
Old Apr 22, 2007 | 01:26 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Easy way to tell if it is the ballast or relay would be to exchange ballast, if that does not work switch wire harness to the one that's out.
I got the same problem in brothers Vette that I need to figure out when he comes up.
For what it's worth I have had a ballast go bad, but was lucky that I got a replacement from not-mee before everything turned upside down.
Old Apr 22, 2007 | 02:43 PM
1KLRTOY's Avatar
1KLRTOY
thank you, I swaped relays and that was it, I just did'nt think about the relays.thanks again KalelC5
Old Apr 22, 2007 | 03:58 PM
KalelC5's Avatar
KalelC5
your welcome.....the relay's are the usual suspect, since I have HID's in both my cars. I did have a ballast go bad in my other car, but the light itself was really dim until one day it didnt go on at all....glad ya fixed it
Old Apr 22, 2007 | 04:37 PM
jdmvette's Avatar
jdmvette
Night Owl for life
also, you can find the replacement D1S bulbs for 150/pair, not 150 each on ebay.
i'm going to get a set of 6000k bulbs soon.
To ACA HID problem
