lowering question
Old Apr 22, 2007 | 05:56 PM
brad6285's Avatar
brad6285
Default lowering question
i lowered my 03 ae vert all the way on the stock bolts. im happy with the back but the front seems to be even higher then before i did it. this is probably due to the rear going down so the front went up a little. i hear members saying about settling and itll go down. i went out for a ride today to hopefully get it to settle. how long will this take. im not very happy with the front (i have 18s with 255/35s gy gsd3s) and i really dont want to cut the bushings but may have to. if you cut the bushings about 1/3 how much will the front drop? thanx brad
Old Apr 22, 2007 | 06:03 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
It will probably drop about a 1/4 of an inch.
Old Apr 22, 2007 | 07:24 PM
brad6285's Avatar
brad6285
ttt
Old Apr 22, 2007 | 07:26 PM
Vega$Vette's Avatar
Vega$Vette
Are you sure you turned the bolt the right way?
Old Apr 22, 2007 | 07:29 PM
brad6285's Avatar
brad6285
i thought we did we turned the bolt all the way down until the retaining clip washers was on the spring is this the right way?
Old Apr 22, 2007 | 07:31 PM
E.C.P's Avatar
E.C.P
St. Jude Donor '07
Brad I sent you a PM. Give me a call .
Manny.........
Old Apr 22, 2007 | 08:55 PM
Vega$Vette's Avatar
Vega$Vette
That's the WRONG way. You turn the bolt counter clockwise (from the top) until it stops. You'll have about 2" of thread showing.
To lowering question
