2002-2004 Vettes
Old Apr 22, 2007 | 07:50 PM
redcorvette96's Avatar
redcorvette96
Default 2002-2004 Vettes
Is there a big difference between the 2002-2004 Corvettes or are they basically the same??? Is the 2002 basically the same as a 2004??
Old Apr 22, 2007 | 09:20 PM
zTrek's Avatar
zTrek
You may want to try some searches on this forum. A lot has been posted on this topic. Just off the top of my head, here are a few key differences I am aware of. These changes apply to 2001-2004 models:
* Use of LS-6 intake manifold and some other tweaks...results in a 5hp increase and more torque at lower RPMs
* Stronger synchros in the transmissions
* Improved 2nd generation active handling which became standard equipment.
* Improved soundproofing.
* Wagon wheels replaced in 2000 with thin spoke versions
* Standard chrome exhaust tips
* Numerous other small tweaks
Hope this helps!
Old Apr 23, 2007 | 11:35 AM
redcorvette96
So the 2002s and the 2004s are basically the same??
Old Apr 23, 2007 | 11:38 AM
02MillenniumVette's Avatar
02MillenniumVette
Basically yes. In the '02-'04 you have a good chance of have the LS6 block instead of the LS1 block. I have the LS6 block on my '02.
Old Apr 23, 2007 | 11:45 AM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
04 had minor differences, primarily computer/electrical related.
If you do a search, you'll find that some parts, etc, are valid from 01-03, and separate p/n for 04.
Diablo predator tuners, for instance.
Old Apr 23, 2007 | 12:06 PM
1976_Stingray's Avatar
1976_Stingray
How can you tell if you have the LS6 Block? I also have a '02 and would like to check.
Old Apr 23, 2007 | 03:03 PM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
The 2003 and the 2004 are basically the same car i dont know about the 2002
To 2002-2004 Vettes
