Just adjusted my E brake and it works.... but only when I pull the handle slowly. If I pull quickly (normal speed) then there is no resistance and it does not work. Anybody have this problem before?
My e-brake didnt grab enough..whether pulled fast or slow...turned out to be a broken pass side e-brake cable...now I can park on MT Everest and she wont move with the e-brake on....
Shoes usually dont wear out as they are not used all that much....unless of course you drive with the e-brake on by accident...then it can wear quite quickly
